View Poll Results: What throttlebody?
Fast 92
![](https://ls1tech.com/forums/images/polls/bar2-l.gif)
![](https://ls1tech.com/forums/images/polls/bar2.gif)
![](https://ls1tech.com/forums/images/polls/bar2-r.gif)
![](https://ls1tech.com/forums/clear.gif)
12
25.53%
Bluemaxx
![](https://ls1tech.com/forums/images/polls/bar3-l.gif)
![](https://ls1tech.com/forums/images/polls/bar3.gif)
![](https://ls1tech.com/forums/images/polls/bar3-r.gif)
10
21.28%
NW
![](https://ls1tech.com/forums/images/polls/bar4-l.gif)
![](https://ls1tech.com/forums/images/polls/bar4.gif)
![](https://ls1tech.com/forums/images/polls/bar4-r.gif)
25
53.19%
Voters: 47. You may not vote on this poll
bluemaxx 90 mm or Fast 92mm throttlebody
A post like that implies that somehow the PTM throttle body is a lower quality part because it uses a different shaft material & that is absolutely not correct. That is nothing more than a direct attempt to make possible consumers think the PTM quality is not top notch. That is just simply not at all true.
I have seen the RevXtreme throttlebody & tons of the PTM throttle bodies & I consider both of them to be top notch!
I can personally tell you guys I can't even remember the last time we had a issue with a PTM throttle body! While other throttle body companies have occassional idle/sticking issues, the PTM throttle body always comes through for the customer.
PTM, Nick Williams, Fast 92mm, and The RevX throttle bodies all look like quality parts IMHO.
But what do I know I've only sold a few thousand throttlebodies...
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
JMG @ Lethal
![Hijacked!](https://ls1tech.com/forums/images/smilies/myhijacked2.gif)
