LSX Heads release date?
Old Nov 10, 2008 | 10:35 AM
ZO6 LandRocket's Avatar
Default LSX Heads release date?
Anybody heard anything at SEMA?
Old Nov 10, 2008 | 10:58 AM
CalSpeedPerformance's Avatar
The head GM engineer that designed them and the LSx block told me the GMMP LSx "DR" (drag race) heads will be on the market within 6 months with 6-bolt setup on them
Old Nov 10, 2008 | 11:04 AM
What about the the non drag race versions?
Old Nov 10, 2008 | 01:28 PM
Dark Shadow's Avatar
what are the differences between the two?
Old Nov 10, 2008 | 09:45 PM
The none DR heads are an LS7 style head with thicker decks, smaller ports, and a 6 bolt design. Check out another thread here that shows and explains what the DR heads are all about.
https://ls1tech.com/forums/generatio...-dr-heads.html
Robin L.......anymore updates!!!!!!!!
Old Nov 12, 2008 | 05:35 PM
Torlow's Avatar
Is there more info somewhere on the non-DR heads? What is the port volume?
Old Nov 12, 2008 | 08:06 PM
Robin L's Avatar
LS1Tech Sponsor
First thing the person you talked with agt SEMA is not an engineer. He was certainly a major contributor to the team that has developed the LSX block and the LSX Heads.
I don't have the port volumes on the High Port LSX 6 Bolt DR heads. Hopefully I can pour them in the next few weeks.
The information on the LS7 Style as well as the LS3 Style heads is out there if you looked at the models on the rack last year and this year. Port Volumes should be the same as OEM on these heads. The changes will be in the thickness of the deck as well as the port walls. They will have the 6 bolt LSX blot pattern and will have larger spring pads.
That is all I know at this point.
Robin
Old Jan 15, 2009 | 09:35 AM
ringram's Avatar
Any update on these heads? The non DR ones that is..
