Is this cam good for L92 heads????
Old Nov 16, 2008 | 04:58 PM
SIC LSX's Avatar
Default Is this cam good for L92 heads????
235/237 599/602 112+2 cam friend of mine has a lq9 6.0 with patriot ls6 heads and thinking about swapping to l92 setup. he is running a carb and vic jr intake. He runs runs 6.90's N/A on motor and 6.50 with small shot in the 1/8th with current setup and just wants the extra. His heads only flow like 298cfm and the l92's flow around 326cfm.
Old Nov 16, 2008 | 06:24 PM
dlove's Avatar
sounds about like most.
Old Nov 16, 2008 | 06:31 PM
xdanny510x's Avatar
im running a 230/244/114lsa in my ls3/l92 stroker
Old Nov 16, 2008 | 07:34 PM
edcmat-l1's Avatar
Far from optimum, but it would work.
Old Nov 17, 2008 | 07:10 AM
WKMCD's Avatar
It will make the valves go up and down if that's what you're asking but you could do better.
Old Nov 17, 2008 | 09:49 AM
the_merv's Avatar
Mine is a 243/247, .621/.612, 114+3 in my 402 Stroker.
Old Nov 18, 2008 | 06:23 AM
WizeAss's Avatar
If you see my thread below you will see that by swapping from a 236/236 to a larger split 236/248 I made some power. I have ported L92's and a carb intake with efi.
Old Nov 18, 2008 | 07:00 AM
the_merv's Avatar
^^You changed some other things in the Drive Train that led to a discussion of that you can't 100% pin point that.
