Tsp giant in 408
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
I'm not saying he won't make power Matt, but with a set of heads like this where the intake side flows soo much better than the exhaust side, it would be beneficial to have a cam compensate for this.
Valve Lift/// Intake L92/// Exhaust L92 Intake/// Exhaust Flow%+- vs. Intake
0.100/// 72/// 63/// 87.5
0.200/// 148/// 126/// 85.1
0.300/// 212/// 162/// 76.4
0.400/// 264/// 189/// 71.6
0.500/// 302/// 205/// 67.9
0.600/// 322/// 214/// 66.5
0.700/// 316/// 221/// 69.9
Valve Lift/// Intake AFR 205/// Exhaust AFR 205/// Exhaust Flow%+- vs. Intake
0.100/// 140/// 112/// 80
0.200/// 200/// 170/// 85
0.300/// 251/// 203/// 80.9
0.400/// 281/// 221/// 78.6
0.500/// 292/// 226/// 77.4
0.600/// 298/// 230/// 77.2
An optimal cam for one set of heads will work for another set of heads, but it will be far from optimal for another set of heads.
IMHO L92 heads need a big split to take advantage of their potential ,small splits give only mediocre results at best. I mean if Comp Cams doesn't know what to recommend then who does?
