N/A 434 LSX Build
I would rather not call anyone out. The crank was a bad part and the reason why the motor blew apart. Too much crank end play and no thrust walls on the main journal. It should have been caught when built. It was a scat crank, and garbage. But the piston to head contact is definitely poor workmanship, and thicker gaskets should have been used. It was overall a mess especially because it had gasket sealing issues as well, and I've never put any power adders through this and tuning is great and constantly monitored and adjusted myself. Never saw any ping or detonation etc...
Regardless, the new build is in progress
PM'ed you a video of it idling and revving. Maybe they can help you with the E85 tuning.
think 13:1. It would make killer power and you would still be on "pump Gas"
Could I get a copy of that video?
Otherwise it uses way more fuel and power output is less.
http://en.wikipedia.org/wiki/Fuel_efficiency
Not sure about any take out Katech cranks? The rotating assembly thats on its way is all brand new stuff. I'm sure Billy will be on a lookout for anything funny when building the motor. Hopefully it will all work well in together!
What are some other detriments to having the heavy rod other than parasitic loss?
Couldn't you use a lighter flywheel and clutch to offset some of the additional weight of the rotating assembly?
