6.2L Escalade Block w/L92 Heads G6x3 Cam
Old 03-03-2009, 08:55 PM
nycblazer's Avatar
Thumbs up 6.2L Escalade Block w/L92 Heads G6x3 Cam
Bought a used 6.2L Cadilac Escalade engine
6.2L stock bottom end w/ stock L92 Heads & stock Truck Intake
G6x3 Cam is it possible.
Looking for some help from you guys in making my final decision.
This is what I'm looking to get so far
G6x3 Cam from LG motorsports
Comp 921 spring kit
Comp pushrods
LG 160 Thermostat
LS2 timing cover
don't know wich timing chain to get
the lifters too but don't know wich ones to get
high performance oil pimp from Lingenfelter Performance
http://cgi.ebay.com/ebaymotors/ws/eB...link:middle:us
07-08 LS2 LS3 L92 L76 Single Bolt Cam Conversion Kit
(DO I NEED THIS) i dont think soo
http://cgi.ebay.com/ebaymotors/ws/eB...3AIT&viewitem=
getting ready to make place my orders but need to really make sure I Got all the right parts here's a detailed description of this engine
The L92-a new standard in truck engines
with out ECM and Wire Harness. Standard equipment on the all-new 2007 Cadillac Escalade and GMC Yukon Denali, the L92 has brought Corvette technology into the truck market. The L92 engine brings you the same 403-horse effort from a 6.2L Vortec V-8 small-block that borrows from all of the features that have made our LS Family of engines world renowned for their efficiency, design, and performance. Now, the L92 is available to you as a crate engine from GM Performance Parts. The 6.2L L92 engine features an all-aluminum design; deep skirt 6-bolt main LS block; variable valve timing; coil-on-plug design; high-flow L92 heads designed with influences from the LS7 Corvette cylinder head; true four-into-one exhaust manifolds; high-volume intake plenum; beehive valve springs; cast-aluminum rockers on needle bearings with roller tips; and a large-volume throttlebody. All together, the L92 kicks out an astonishing 403 horsepower and 417 lb.-ft. of torque with a broad, powerful torque band. The L92 is the next great small-block truck engine from GM. Get your L92 crate engine from GM Performance Parts, and get your project car or truck moving in the fast lane.
Part Number: 19165485
Engine type: LS Series Gen IV small-block V-8
Displacement (cu in): 376 cu in (6.2L)
Bore x stroke (in): 4.06 x 7.62 (103.25 x 92mm)
Block (P/N 12568950 / 12589485): Cast aluminum with 6 bolt, cross-bolted main caps
Crankshaft (P/N 12584997): Nodular iron
Connecting rods (P/N 12604629): Powdered metal
Pistons (P/N 12584087): Hypereutectic aluminum
Camshaft type (P/N 12612273): Hydraulic roller with phasing
Valve Lift (in): .500 intake / .500 exhaust
Camshaft duration (@.050"): 198° intake / 209° exhaust
Cylinder heads (P/N 12582713): L76/L92 rectangle port; as cast with 70cc chambers
Valve size (in): 2.16 intake / 1.59 exhaust
Compression ratio: 10.5:1
Rocker arms (P/N 12569167 int): Investment cast, roller trunnion
Rocker arms (P/N 10214664 exh): Investment cast, roller trunnion
Rocker arm ratio: 1.7:1
Recommended fuel: 92 octane
Maximum recommended rpm: 6000
Reluctor wheel: 58X
Balanced: Internal at bottom
Old 03-04-2009, 08:34 AM
Brad Hutchcraft's Avatar
almost have it! I am also going to point out, depending on the vehicle that you are swapping this into, that you are going to need a cable throttlebody and bracket from SLP. you might need the L76 intake manifold. You are going to need the Lingenfelter crossover box if using a computer with 24t reluctor outputs. depending on if it has afm, you will need to change the lifters to an LS7 lifter or something similar. I believe the PV will be sufficient with the chamber size on these cylinder heads, but I wouldnt mill much without first checking for clearance. You will probalby need an F Body oil pan and you will need to tap the block for the knock sensors like on an LS2. also going to need the LS2 cam sprocket, balancer assy, TPS and IAC sensors from your TB, and some assorted harness extensions which you can get from KATECH or caspers or Racetronix... I believe there is a sticky for this as well.. good luck!
Old 03-04-2009, 03:58 PM
nycblazer's Avatar
thanks for your info there Brad Hutchcraft
the engine is gonna go in a 4 door blazer and i want to keep the 58x reluctor ring.
the drive by wire throttle and pedal I already have.
The electronic pedal is also installed in the blazer.
I really don't want to do any cutting or machining to the heads or the block, looking for parts that'll keep it stock.. is it possible, with the g6x3 cam
Old 03-04-2009, 04:10 PM
l92
l92's Avatar
have you talked to lg motorsports about this setup and if so what did they have to say abount the cam
Old 03-04-2009, 04:41 PM
01badz28's Avatar
I'm doing the same thing you are doing, except my L92 is going into an F-body.
So far this is the crap I'm running:
LS3 hollow stem valves
Patrick G custom grind cam
Comp cams pushrods
Patriot extreme double valve springs
C5R timing chain
Katech Belt tensioner
Lingenfelter reluctor wheel convertor / cam signal converter
LS3 cam timing gear
LS3 front cover
I have the parts to eliminate the timing chain tensioner found in the L92 (which is something Lingenfelter recommended) and return it to an LS1 style setup
L76 Intake
Cable driven TB
Improved Racing oil pan baffle for the F-body oil pan
LS2 style fuel rail
Racetronix Knock Sensor extension harness
I have read that the L92 truck injectors won't work in the L76 intake, but I don't know yet. I'll use those if I can, if not I've got the Katech kit to use my LS1 style injectors.
Old 03-04-2009, 04:44 PM
nycblazer's Avatar
are you running stock 6.2L L92 bottom end and stock L92 heads?
Old 03-04-2009, 04:52 PM
01badz28's Avatar
Yes, not touching either.
Old 03-04-2009, 05:11 PM
nycblazer's Avatar
those pistons look new
are they new?
Old 03-04-2009, 07:50 PM
01badz28's Avatar
are they new?
The whole engine is new, it was one of the train derailment motors.
Old 03-04-2009, 07:56 PM
nick1ta's Avatar
how much did you pay for it?
Old 03-05-2009, 09:06 AM
01badz28's Avatar
I can't remember the exact amount, but it was around 4K shipped for the complete engine.
Old 03-09-2009, 03:18 PM
PM sent 01badz28! Your motor looks awesome! Good buy!
Old 03-09-2009, 04:11 PM
Ragtop 99's Avatar
While its sitting out, are you going to touch up the heads?
Old 03-09-2009, 07:37 PM
denali-08's Avatar
Cool
I have an l92 6.2 from escalade in a gmc single cam... running good
Old 03-10-2009, 12:43 PM
01badz28's Avatar
I had not planned on it at this point. Next winter I'll probably go with a set of CNC heads and a FAST intake, depending on how satisfied I am with the engines performance.
Old 03-10-2009, 05:33 PM
gectek's Avatar
This is what I'm looking to get so far BLAH BLAH BLAH
You do realize that L92 is already all of that stuff you said right? There is no other L92. They only came in trucks. Anyway
Make sure to specify a 3 bolt cam. There are alot more venders that sell the TBs and Brackets than SLP, for alot better price. The block is already tapped for those knock sensors, since it is newer than the LS2 and does not use the knock sensors under the intake. An F body oil pan would have trouble in that blazer. Looks more like an LH8 pan from an 08 newer H3. He can use that balancer, just has to use the truck serpentine setup. If it has AFM, then you will also have to change the lifter retainers. Obviously the front cover has to be changed. unless you want to just get a plate and block it off.
Old 03-10-2009, 05:44 PM
nycblazer's Avatar
[QUOTE=gectek;11216135]You do realize that L92 is already all of that stuff you said right? There is no other L92. They only came in trucks. Anyway
I know.
I was Just letting whoever answered my question that it was all stock L92
Stock bottom, stock intake and stock L92 heads. all I wanna know is if its possible to just add the g6x3 cam to a L92 stock engine.
or do I need to add other parts to it like cts-v lifters, springs or so.
Old 03-10-2009, 05:59 PM
LS1Tech Sponsor
Beau@SDPC's Avatar
Alot of people will recommend using comp lifters or morels on an aggressive aftermarket can, but then again alot of them will say they use the LS7 lifters with not problems. I would not recommend the high rev caddy lifters at this time. You will def need some new valve springs as well as pushrods to boot IMHO.
LS7 lifters - 12499225
Morels - (boxed as lunatis) 579.05 although im sure there are some other vendors that have those cheaper
Comp - 850-16 229.95 (close to the LS7s)
875-16 245.95 (pro magnums)
Pushrods i would recommend manleys...usual size is the 7.400 $100 per set in any increment above 7.400 or below that manley has.
springs - i would go Patriots period. PPC8501 complete kit. $279.50
Old 03-10-2009, 06:17 PM
nycblazer's Avatar
Originally Posted by John@Scoggin
Alot of people will recommend using comp lifters or morels on an aggressive aftermarket cam, but then again alot of them will say they use the LS7 lifters with no problems. I would not recommend the high rev caddy lifters at this time.
Can I ask why you won't recomend the High Rev Caddy Lifters?
and the Patriots springs is that the correct part number. PPC8501 I check it out on SDparts and came up with no match.
Old 03-11-2009, 09:21 AM
LS1Tech Sponsor
Beau@SDPC's Avatar
Well, there are better designs out there.
And as for the Patriot Springs, no they are not on the site yet, but we always keep them in stock.
Quick Reply: 6.2L Escalade Block w/L92 Heads G6x3 Cam
