Need cam advice for my 427 ls2
Old Mar 13, 2009 | 08:03 AM
expertrm's Avatar
Default Need cam advice for my 427 ls2
I have a ls2 427 with 11:1 compression. I need to know what is the largest cam you guys would recommed. This is my daily driver with AC. I do not want any idle problems. Thanks for the Help.
Old Mar 13, 2009 | 09:26 AM
99blancoSS's Avatar
What heads ? Check out this thread and look at the size of the cam 230/249 BUT he also has All Pro LSW heads on their as well.
https://ls1tech.com/forums/dynamomet...6-results.html
Old Mar 13, 2009 | 09:40 AM
Cliff's Avatar
If you don't want driving issues and this is your only criteria then stick with a stock LS7 cam. Or are you looking for more power and street friendly? Most of the street ability is determined by your turners ability to tune.
expertrm's Avatar
l92 heads unported.
Old Mar 13, 2009 | 10:03 AM
expertrm's Avatar
Thinking of getting a Crane Cam 236/242 with 624/609 lift. for my 427 with l92 heads. How will this cam workout with my setup. Looking for the most power but with driveablity.
Old Mar 13, 2009 | 12:17 PM
6.0monsta's Avatar
How do you get a 427 out of an LS2?
Old Mar 13, 2009 | 02:44 PM
expertrm's Avatar
sleeved it
Old Mar 13, 2009 | 03:07 PM
LS6427's Avatar
I have a 427ci with a 244/244 .610/.610 114 lsa
It literally idles a nats *** near stock "after it warms up for about 2 minutes". Zero lope, zero bounce, zero shake. Idle is set at 975rpm. I have A/C too.
Tune it right and you can go bigger.
Old Mar 14, 2009 | 08:26 AM
ringram's Avatar
heads will determine cam so you need to figure your heads out first.
fast92 and tfs heads seem to work well.
Or ls7/ls7 as above is nice or on a budget an LS3/LS3 setup. WCCH do nice ported LS3 heads.
So as I say sort your heads out first THEN go cam shopping.
