Huge oil leak!!!
Old Mar 28, 2009 | 09:21 PM
CuNfUzEd's Avatar
Default Huge oil leak!!!
Problem. Towards the back of the oil pan,drivers side, there is a 3 inch by 1 inch oil plug. The plug generally has 2 ten mm bolts on the outside that fasten and the center two holes flow oil. I picked up the part, which I thought I misplaced, and it does not fit. The plug itself matches perfectly. The issue is the ceneter oil flow holes are plugged and the outer holes are not threaded. I do have a 4X4 v8 Tb. The oil filter is in a different place than 2x4. Anyone know what I need to put in that location? The techs here at work (Chevy store no less) have no idea.
Old Mar 29, 2009 | 01:10 PM
CuNfUzEd's Avatar
ANYBODY!?!?!?!?!?!? I am about to slit my wrists over here!
Old Mar 29, 2009 | 03:06 PM
-Joseph-'s Avatar
LSxGuy widda 9sec Mustang
Pics?
CuNfUzEd's Avatar
DUH!!! Be right back.
Old Mar 29, 2009 | 03:35 PM
CuNfUzEd's Avatar
Old Mar 29, 2009 | 04:30 PM
CuNfUzEd's Avatar
This normally goes in place. It does match up but the bolts don't fit. I pulled this part from another oil pan myself. I even laughed and said "Nothing can stop me now". I gotta quit doing that **** man. Geeeezzzzzzzz..........
Old Mar 29, 2009 | 05:10 PM
jay_lt4's Avatar
i think we are all a little confused here,, tell us more about this build,, is this the original pan from your 5.3 and all you did was swap it to your new build??, where is the original oil pan?
are those allen socket plugs in the oil cooler holes??
those holes seem to be plugged, i would say your oil leak is from somewhere else, there is a main oil gallery plug just above where you took the picture on the block, or the oil pan gasket got messed up , oil flows through the block and the oil pan gasket to the oil passage holes in the pan to get to the filter
Old Mar 29, 2009 | 05:19 PM
CuNfUzEd's Avatar
Sorry. Same oilpan from the 5.3 that waws in my 06 Trail blazer. I have now put in a 408. I reused the old pan and can not for the life of me figure out why I would of removed that piece and then......WTF went there.
I visually have seen the oil flow from these holes. You can also see clean spots where something was mated on there. EVERY LSX oil pan I have seen has the piece I have pictured here. I have yet to look at another V8 4X4 TB. The front diff's are WAY different from a regular GM 4X4. The axle shoots through the oil pan.
Also I can stick a screw driver all the way in to the holes.
Old Mar 29, 2009 | 05:22 PM
CuNfUzEd's Avatar
Also the oil filter is relocated to the passenger side front along with the dip stick.
Old Mar 29, 2009 | 05:33 PM
jay_lt4's Avatar
did you put this part back in the pan and bolt it up??
Old Mar 29, 2009 | 05:57 PM
CuNfUzEd's Avatar
Oh ****
Old Mar 29, 2009 | 05:58 PM
CuNfUzEd's Avatar
I never took that out though.
Old Mar 29, 2009 | 05:59 PM
CuNfUzEd's Avatar
Ah...That is what I am feeling with my screw driver. If I can't get that to screw on, I will need to pull the whole thing again as the oil pan is one piece back plate to pan.
Old Mar 29, 2009 | 06:12 PM
CuNfUzEd's Avatar
If I have the allen head plugs in from the factory, it should be holding the tube on. Hopefully. My block is not threaded in that location and the other blocks have been.
Old Mar 29, 2009 | 06:14 PM
jay_lt4's Avatar
the oil pan will come off with the engine in the vehicle,, also the front diff will come out by itself,, i have done several at work with the 5.3 in them
Old Mar 29, 2009 | 06:21 PM
CuNfUzEd's Avatar
Really? How do you unbolt the back plate?
Old Mar 29, 2009 | 06:34 PM
jay_lt4's Avatar
what back plate??
-remove oil dipstick
-remove your axle shafts
-take off the 4x4 coupler on the pass side of the pan
-pull out the short axle stub shaft
-un bolt the front diff assembly and push it to the side, or remove it, it will come out with some fanagling
-remove the starter and inspection covers
-remove ac compressor bolts
-remove the oil pan bolts
-Remove the oil pan by tilting the rear of the oil pan down to clear the transmission, pull the oil pan rearward past the front wire harness, then lower the oil pan clear of the vehicle.
Old Mar 29, 2009 | 06:43 PM
CuNfUzEd's Avatar
LOL The back side cover is one piece with the oil pan. I know I had it in my hands and even put in the new rear main seal. I know mosty 5.3 engines have face plate, back plate and oil pan. This rig just has a two piece setup. My first thoughts upon seeing it where I liked it for the fact it would reduce leaks. Then I imagined a situation like this and didn't feel it was that great of a desiegn. Made for slipping the pan over the oil pick up tube fun too.
Old Mar 29, 2009 | 07:02 PM
jay_lt4's Avatar
the rear engine cover bolts to the oil pan on everything i have ever seen,, i can see the bolts in your picture you posted,,, those 2 rear oil pan bolts hold the rear cover to the oil pan
Old Mar 29, 2009 | 07:08 PM
CuNfUzEd's Avatar
I really wish now I had pics. I did take some but the memory card got corrupted. I didn't get to post as complete build pics as I would of liked. It is truely strange to look at. I think this is a reason why I am having issues with this. The truck was a custom order unit from the factory. It is a 5.3 nonext which just doesn't happen. I guess I will thread the hole and plug the damn thing. What could it be screwing up if I did? Anyone?
