Valve locks for L92's
Old Jun 10, 2009 | 05:19 PM
tennerv8's Avatar
Default Valve locks for L92's
I need some valve locks for my stock L92 valves. Will just a regular Ls1 valve lock work? Thanks fellas.
Old Jun 10, 2009 | 06:28 PM
tennerv8's Avatar
Anyone? You guys are killin me!
Old Jun 10, 2009 | 06:31 PM
narcszm's Avatar
Yes, it will.
Old Jun 10, 2009 | 08:25 PM
SweetS10V8's Avatar
yup, any LS lock will work
Old Jun 10, 2009 | 09:31 PM
tennerv8's Avatar
Any recomendations? Are they all created equal? Would something like this be sufficient? They seem to be genuine GM parts.
http://cgi.ebay.com/ebaymotors/Chevy...171|240%3A1318
Old Jun 11, 2009 | 08:10 AM
tennerv8's Avatar
Wonder if they are the same as what the dealer carries.
Old Jun 12, 2009 | 10:18 AM
tennerv8's Avatar
Bump..............
Old Jun 12, 2009 | 10:31 AM
Beau@SDPC's Avatar
LS1Tech Sponsor
as long as they are LS valve locks, they will work. If you want aftermarket, then prob the comp 623 or manley will work for you. I have all those on hand, both the GM and the comp and manley. For the most part, the L92 uses the same valvetrain (besides the valves of course) just like the rest of the LS heads. Some differences like steel caps for ti valves on the LS7 and a few diff spring types, but the locks are the same from the run of the mill LS heads
and they are actually the same as some other locks from the GM V6 engines and others as well.
Old Jun 12, 2009 | 11:43 AM
tennerv8's Avatar
Great thanks
Old Jun 12, 2009 | 12:28 PM
tennerv8's Avatar
Also do I need spring bases with the L92 seals?
Old Jun 12, 2009 | 12:29 PM
Beau@SDPC's Avatar
LS1Tech Sponsor
No, the stock valve stem seal is ALSO the seat.....tophat style. its all one piece
Old Jun 12, 2009 | 12:46 PM
tennerv8's Avatar
Do you know if these take a lot of shimming to come into spec? 1.800 is what my valve springs say to install at.
Old Jun 12, 2009 | 12:48 PM
Beau@SDPC's Avatar
LS1Tech Sponsor
that is normal LS installed height. they are all roughly the same thickness, but some shimming may be required to reach your installed height that you want. most of the time they will be very close though
Old Jun 12, 2009 | 12:50 PM
tennerv8's Avatar
Do you think I should just let it ride? The cam will be .573 lift
Old Jun 12, 2009 | 01:00 PM
Beau@SDPC's Avatar
LS1Tech Sponsor
i do not personally see a need to go about fine tuning the valve train as such to that extent for just a mild cam. but make sure you have better springs than stock/LS6...because that is right on the line of the LS6ers.
Old Jun 12, 2009 | 01:08 PM
tennerv8's Avatar
I picked up the pac 1218's
Old Jun 12, 2009 | 01:15 PM
Beau@SDPC's Avatar
LS1Tech Sponsor
if it were me, i would just put them on and let it ride
Old Jun 12, 2009 | 01:17 PM
tennerv8's Avatar
Do i need to lapp the valves. Valves are brand new never used as are the heads.
Old Jun 12, 2009 | 01:18 PM
Beau@SDPC's Avatar
LS1Tech Sponsor
that is completely up to you on that deal. I do, but that is my personal approach
Old Jun 12, 2009 | 01:20 PM
tennerv8's Avatar
What grit or grain do you use?
