440 nitrous
Old Sep 9, 2009 | 07:19 AM
Austin@HPE's Avatar
Default 440 nitrous
My friend just got his 440 ls7 what size head gaskets should he use. I know stock ls7 gaskets measure 4.150 he is looking to get cometics for alot of nitrous. Is this the best size?
Old Sep 9, 2009 | 07:24 AM
Ron@Vengeance's Avatar
Your friend will need to calculate his compression and order the head gaskets accordingly. I would ASSume he would run a 4.200 Bore x .040 Cometic, but its going to depend on piston configuration/combustion chamber CC/desired compression..
Old Sep 9, 2009 | 07:46 AM
Austin@HPE's Avatar
its using tfs235 it was built to 11.5 using stock gm mls gaskets
Old Sep 9, 2009 | 07:50 AM
Austin@HPE's Avatar
I dont see a 4.200 on cometics website.
Old Sep 9, 2009 | 08:00 AM
Robin L's Avatar
LS1Tech Sponsor
What bore size is the 440 ?
What block?
Cometic makes a 4.185 that is sold through GM Performance Parts for the LSX 6 bolt heads.
Robin
Old Sep 9, 2009 | 08:03 AM
Austin@HPE's Avatar
4.125 bore x4.125 stroke its a brand new ls7 block
Old Sep 9, 2009 | 09:09 AM
ATVracr's Avatar
If its a N20 motor make sure the quench isnt to tight.
Old Sep 9, 2009 | 05:38 PM
Gordon0652's Avatar
I am building an LS7 440 and i will be spraying at most a 225shot and i am going to run the stock LS7 MLS gasket. (4.130 x 4.100)
Old Sep 9, 2009 | 05:54 PM
3timeracin's Avatar
The most important thing to calculate is the deck height ! that will impact the actual gasket thickness needed to get the correct quench and not detonation or piston to head contact.
Old Sep 10, 2009 | 10:23 AM
Austin@HPE's Avatar
thanks guys we are getting 4.150 .051 thickness cometic gaskets.
