2.20 intake valve in an LS3 Head?
The flow dynamics of L92 (and LS7) heads may be different from what we are used to. Just enlarging the valve without doing corresponding work to the port probably is not a good idea. I don't doubt that Richard may make a larger intake valve work in the L92 head.
If you thought cathedral port LS heads confused some head people, y'all ain't seen nothing yet! I think we will see quite a few different approaches to making L92 heads work better than stock. From what I've seen so far, not all "reworked" L92 heads are an improvement. Some are of course.
Jon
511-204 "Bare Large Bore"
LS3 12 Degree 4.125"-4.200" Bore 6-Bolt CNC Cylinder Head
Utilizes the Gen IV LS7 valvetrain and valves, but accepts the LS3/L76 intake manifold.
Designed for any new Gen IV short-block with 4.125" bore or larger.
The 6-Bolt design is compatible with GM LSX and World LSX blocks.
Uses a 2.200" Intake Valve and 1.610" Exhaust Valve
Only cylinder head on the market to utilize LS7 valvetrain components and accept the LS3 intake manifold.
Thats taken right from Mast's site. I really like those Mast Heads, expensive though.
Edit: Large bore Ls3 heads use a 2.20 intake 1.60 exhaust.
The problem is that the LS3 valve spacing is larger than both the LS7 and LS6 heads, so the same valve configuration in an LS3 head is going to be closer to the bore wall and consequently more shrouded. If you have the bore big enough to fit say a 2.20"/1.60" valve combo, you're better off starting with an LS7 head.
