285cc PRC LS7 CNC Ported 415+cfm Cylinder Heads Now Available
http://www.texas-speed.com/shop/item...=1087&catid=40
Check out our site. At the bottom you can price the heads with different casting, spring, and valve options!![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Jon
Jon
If it is per head, then it is too expensive (as compared to other cylinder heads on the market).
Should be interesting to see how they perform.
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
LS1Tech Premium Sponsor
^^It is outright, and for the pair
It's great that once you add the options for the spring kit, valves, etc onto it....you get into a double throw down cylinder head, for just a little more than the standard CNC'd GM head (and a nice chunk of extra power too)!
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic110569_2.gif)
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Jason and Matt, if you guys want/need another test car for the heads, let me know. I've got a 500 cid ERL motor in my car with pretty much stock LS7 heads with some exhaust work. I can probably drive the car out to Lubbock for a couple days.
#33
That's correct. Quantity of one gets you a pair. Quantity of 2 gets you TWO pair.
__________________
#35
OWN3D BY MY PROF!
^ An intake only restricts air flowing through it, not stop it completely. An increase in head flow with something like a FAST or LS7 intake will not completely limit a head to the point where it will make no more power.
Do I agree with you that ITB intakes make more power? Yes, I do. Do I believe the Harrop is the best option? Absolutely not, and I've heard of a lot of design and installation flaws in regards to them.
#38
I asked for around 11.75:1 compression. Who knows if the engine builder combined with the shop got close to that number? Cam is a ~260 duration/~.700 lift hydraulic roller. I'll take a couple videos of it idling when I get home tonight.
I'm looking to pick up an additional ~30hp and slightly improve driveability. I'm hoping a few little tweaks can achieve that.
#39
The ITB intakes, whist good for track racing, are less than ideal for street cars. Yes, they make more power and can make a big cam idle smoother (due to dissipating the reversion), but they also require constant attention and a high degree of fiddling.
The reason you would choose ITBs over single or dual TBs would be the fact that you can have up to unlimited plenum volume, which increases the strength of your harmonic pulses and reduces airflow resistance. And due to the fact that you have the throttle plates close to the intake valves, the throttle response is excellent (sometimes to the point where the accelerator pedal is too responsive) - ideal for on/off type racing.
For a street car that needs to have an airbox that fits under a hood, the ITBs dont make as much sense. I have heard that the Harrop has a significant drop in power once the airboxes are fitted. A well designed intake with a single TB is probably the best option for 95% of applications. Then take your spare $5,000-10,000 and use it in other areas like brakes and suspension, which will make you faster on the track compared to the car with the ITBs.
