Looking into LSX
Old Feb 11, 2008 | 07:45 PM
COOKIE MONSTER's Avatar
Default Looking into LSX
Hey guys,
I'm starting to save up for an LSX setup. I want to NA for the next 2 years or so. If you're running LSX 427ci, and your NA, what crank, rods, heads, cam etc, did you go with? And how do you like your setup?
Old Feb 11, 2008 | 09:13 PM
Bump^^^^^^^^^^^^
Old Feb 11, 2008 | 09:20 PM
Damn, I'd think a lot of people on Tech would be tuned into any thread with the letters LSX in it...
Old Feb 11, 2008 | 09:28 PM
Bump^^^^^^^^^^^
Old Feb 11, 2008 | 10:29 PM
Drew04GTO's Avatar
6" bore 2.83" stroke. Callies crank, Oliver rods ETP 335cc heads. 975whp @14,000 rpm 87 octane.
Old Feb 11, 2008 | 10:37 PM
Tom@SpeedInc's Avatar
LSX blocks are on intergalactic backorder.......
Old Feb 11, 2008 | 10:56 PM
xfactor_pitbulls's Avatar
****** smartass
Old Feb 12, 2008 | 06:25 AM
speedracer5532's Avatar
Run a 4 inch Callies crank, 6.125 Compstar rods, pretty much all pistons manufactures have good pistons, 11.5-11.8 SCR and 8.5-9.0 DCR, Lots of good heads out there, you don't need 6 bolt heads for staying N/A.
Old Feb 12, 2008 | 06:34 AM
Stang's Bane's Avatar
Originally Posted by speedracer5532
Run a 4 inch Callies crank, 6.125 Compstar rods, pretty much all pistons manufactures have good pistons, .
Good advice.
When you say NA for 2 years, are you planning on spraying it then or going FI??
Big difference
Old Feb 12, 2008 | 08:59 AM
To be honest, I dont know why you would want to run an LSX based 427 NA over an LS2/LS3 based 402/416. The difference in weight, cost, and availability is relevant. In NA form, the aluminum blocks are just fine for strength and what you gain in bore HP (LSX), can be very close to equalized with the right head/cam/intake setup on the factory aluminum blocks.
Old Feb 12, 2008 | 10:59 AM
Jimbo'sZO6's Avatar
Thumbs up
You got that right!
Jimbo
Old Feb 12, 2008 | 11:01 AM
****** smartass
14,000 rpms? lol 6" bore ha ha
Old Feb 12, 2008 | 11:04 AM
Originally Posted by Stang's Bane
Good advice.
Big difference
Well, I plan on running the motor NA, and Chemically Aspirated...
Old Feb 12, 2008 | 04:59 PM
tcr98taws6's Avatar
LSX Block (454)
4.187 Bore
4.125 Stroke
11.8 Compression
Callies Crank & Rods
Wiseco Pistons 2cc VP's
Trickflow 235 Heads
Cam Motion Camshaft
Ported FAST 90
Nick Williams 90mm
A/R 1 7/8" Merge Headers
3" True Dual Magnaflow Mufflers
93 Octane Gas
A/C and Power Everything
624RWHP / 578 RWTQ
Street manners, 17 MPG highway at 70 MPH with A/C running
Wheels in the air on slicks and skinnies
Old Feb 14, 2008 | 10:53 AM
93TAWicked1's Avatar
I have the same shortblock trc88taWS6 has with older TEA stage III 317 head for big bore motors, Smallish cam and still run the MAF. It drives like a mid 230's cam in a 346 car. I have an extremely mild build through the SLP Dual dual exhast pulled numbers in the sig on a mustang dyno through a 9 inch.
