L92 non dod lifters
Old Feb 9, 2010 | 06:05 AM
Gray86hatch's Avatar
Default L92 non dod lifters
What is the story on these lifters.
I have a nice clean set. I have not really found any info. Are they comparable to a ls7 or what.
Thanks
Tim
Old Feb 9, 2010 | 07:16 AM
Robin L's Avatar
LS1Tech Sponsor
Yep, standard LS2/LS7 lifter.
Robin
Old Feb 9, 2010 | 08:51 AM
Thanks Robin
You going on power tour this year? We will be there with the bb 71 chevelle. Going to stop and Bob's on the way to say hi. I hope we don't need the lift again.
Tim
Old Feb 9, 2010 | 08:59 AM
Robin L's Avatar
LS1Tech Sponsor
No problwm. No power tour for awhile. Wanting to get back out with the Nova again. Calandar is fillng up, It's going to be a busy year this year.
4 NMCA Races with the Nova
True Street NPS classes 8 races
John Ryan's Motor City Rumble
Holley LS Fest in Septemeber
LSX Shootout in October
I had wanted to do the Camaro5 event as well as Hot Rod Drag week but I think that I will be short on vacation time as well as $$$ LOL.
Good luck!
Robin
Old Feb 9, 2010 | 09:30 AM
I hear you on $$ vacation I have 5 weeks. 3 are used up with DW PT and a wedding. Wife wants a week also. Like to drive my car to super bowl. Also like to do the LSX deal at milan.
Just have to see how things go. The parts are comming in and my taxes are double what I thought.
Tim
Old Feb 10, 2010 | 04:35 PM
rsz288's Avatar
Robin
Have GM moved away from their regular lifters for regular production engines?
Old Mar 14, 2010 | 04:27 PM
cam's Avatar
cam
Robin where did you source the info on the L92 lifters being the same as the LS7 lifters? I only ask as there seems to be some confusion over at performance trucks that the L92 lifters are not only different, but inferior which Im doubtful of and hoping you can clarify? Thanks
Old Mar 14, 2010 | 07:02 PM
rsz288's Avatar
Good question. Have not seen an LS7 lifter in any 6L production engine whether DOD or non DOD. Lower cost lifters only without top end oil feed check valve. Only constant flow to top end.
Old Mar 20, 2010 | 01:53 PM
cam's Avatar
cam
Odd when i search out the PN's for stock L92 lifters I come up with this;
17122490 which is the LS7 lifter also
So how does this mean they are different?
I've found numerous threads stating that they are the same lifter used in the LS3/L92 non DOD applications.
Heres a couple
https://ls1tech.com/forums/generatio...omparison.html
http://www.performancetrucks.net/for...d.php?t=428941
Unless someone else can clearly prove that these are different pieces then as far as Im concerned this case is closed.
L92/LS7 lifters are the same
so long as the L92 is non DOD that is but anyone confusing those lifters with regular lifters shouldnt be wrenching anyways as they look radically different from one another.
