Lets find the TR224 version of a VVT cam
So does one just install it dot-to-dot and call it good? Maybe just check the piston to valve clearance? I received my VVT3 cam from TSP and there is not a cam with it.
https://ls1tech.com/forums/generatio...vvt-cam-2.html
If you use the correct phaser for your cam core, you install dot-to-dot and you're set. Since you can't compare what you find to a cam card, as long as you get numbers that make sense, you have to take it on faith.
Sorry to step on your thread again CAM...
I have zero to gain by posting anything here other than trying ( keyword TRYING ) to help anyone else out there who is curious about a VVT cam swap that is worth the hassle which is what REALLY rots my socks off. No good deed goes unpunished i guess. I spoke with a lot of people when I started this build and was really focsued on the cam itself and had a much better understanding of it all then.
Anyways theres lots of other great threads about what needs to be done and how to check for PTV with VVT and whatnot. But after all the gremlins that popped up on this swap im totally burnt out of explaining each step of the way hence my edgy responses. Hell I barely post anymore as a result this build was brutally complicated on so many fronts and the cam was truly one of the easiest things to deal with because I simply clicked
here
I just wanna go fast and I like to build stuff that lasts the test of time and punishment. Im not the guy who builds the car that makes 5 fast passes and blows up. Even the tune is street safe its not about extracting every last drop of power its really about smiles per mile as I like to say.
I must say though that now that its done? It drives very VERY nicely. Only thing im really not happy with is the Tex Z grip its too radical a clutch for DD use plus im having shifting issues but now that the engine is sorted out its so cherry pie I bomb around pretty much everyday somewhere.
If I was to compare this cam just on driving style vs the TR224 Id say its milder. Im sure the larger cubes mellow it out further than it would behave on a 346 plus the DBW is a hell of a lot easier to tame at low RPM than a cable TB but its pretty smooth. Nice idle though. I can at least post a vid of that sometime soon to get back on track with this thread LOL.
Thanks, that makes it perfectly clear.
with one of your statements and this is a public forum.
I think you probably picked a great cam and it sounds like great results. Good luck.
thanks,
Jim
Im glad to answer any questions and share tunes.
