lq4 compression estimates??
Old Mar 3, 2010 | 08:03 PM
jasonsnova's Avatar
Default lq4 compression estimates??
so what do you think i'll have for compression? lq4, ls3 heads milled to .035, cometic .045 gaskets, piston comes out of bore .005.....any estimates. was thinking around 10.6 but i'm guessing
Old Mar 3, 2010 | 08:08 PM
69LT1Bird's Avatar
sounds about right
Old Mar 3, 2010 | 08:21 PM
jasonsnova's Avatar
once i get the heads back then i can measure my push rod length....then i can put her together...cant wait! haha
Old Mar 3, 2010 | 08:56 PM
69LT1Bird's Avatar
what cam did you go with?
Old Mar 4, 2010 | 06:22 AM
jasonsnova's Avatar
i went with the texas speed cam, 225/230 .617/.612, hopefully its big enough and i'll be happy with it.... http://www.texas-speed.com/shop/item...=1055&catid=44
its made for the ls3 heads supposedly, they told me any bigger and i'd have to flycut alot and would loose comp and it would be a wash.... we'll see
Old Mar 5, 2010 | 04:45 AM
jaber911's Avatar
Here is a stock bottom end LQ4 compression calc breakdown using stock LS2/LQ4/LQ9 Head Gaskets:
72cc - 9.47:1
71.06cc (stock 317 chamber) - 9.56:1
71cc - 9.57:1
70cc - 9.67:1
69cc - 9.77:1
68cc - 9.87:1
67cc - 9.98:1
66.67cc (stock LS1 241/853) - 10.01:1
66cc - 10.09:1
65cc - 10.20:1
64.45cc (stock LS2/6 243) - 10.26:1
64cc - 10.31:1
63cc - 10.43:1
62cc - 10.55:1
61.15cc (stock 5.3 706/862) - 10.66:1
61cc - 10.68:1
60cc - 10.80:1
59cc - 10.94:1
58cc - 11.07:1
57cc - 11.21:1
56cc - 11.35:1
Old Mar 5, 2010 | 05:35 AM
69LT1Bird's Avatar
That's all fine if he was using those heads and head gaskets. He has LS3 heads and will need to use LS3/L92 head gaskets which have a bigger bore diameter, heads are also milled.
Also, not every one is the same, it depends how far above the deck your piston is also.
Old Mar 5, 2010 | 06:41 AM
jasonsnova's Avatar
i thought about going down to .040 off the heads but i didnt want to mess up intake fit, checked it last night and it seems to be right at the limit, any more off the heads and id have to cut the intake too. i probally could of got away with a .030 head gasket too but i settled on the .045's...... waiting on my springs and a push rod checker tool then i can assemble and order the push rods......gettin there!
Old Mar 5, 2010 | 07:30 AM
69LT1Bird's Avatar
If you are out of the hole .010", like most LQ4 engines, the .045 will put you right at .035 quench where you want to be.
Old Mar 10, 2010 | 07:33 PM
billy.johnson's Avatar
looking to put LQ4 with 59cc heads whats the best cam with all the boltons in a 98 camaro. Im thinking street sweeper or MS3 ???
