Has any one used the TEA L92 CNC Stage 2 heads
Old 03-20-2010, 04:30 PM
LS6
LS6's Avatar
Default Has any one used the TEA L92 CNC Stage 2 heads
TEA L92 CNC Stage 2 looks very nice with exellent flow number espically on the exhaust side...
Has any one used them on a 6.0L engine with excssive 550 rwhp and 500 rwtq...
From what I see, it looks very promissing, they overflow a stock LS7 and some LS7 CNC stage 1...
TEA L92 CNC Stage 2, Minimum Bore 4.000”
Lift Intake Exhaust
0.100 71 55
0.200 155 118
0.300 240 190
0.400 302 253
0.500 344 273
0.550 358 280
0.600 360 284
Old 03-20-2010, 11:24 PM
LS6427's Avatar
Damn good. That 284 exhaust is AWESOME.....
Old 03-20-2010, 11:37 PM
Stang's Bane's Avatar
TEA flows all of their exhaust ports with a 1 7/8 pipe installed so those numbers are higher than just the port alone numbers.
Old 03-20-2010, 11:57 PM
Wnts2Go10O's Avatar
isnt the pipe making it more "realistic"?
Old 03-21-2010, 01:12 PM
GregRexAdams's Avatar
Maybe, but when comparing to another head, it's necessary info to know so you are comparing apples to apples.
Old 03-23-2010, 11:53 AM
LS6
LS6's Avatar
it seem that no one used these head
from what I see, the WCCH & AI L92 CNC head are explosive power maker
Please, if someone have experence with these head, apprichated to share the power that generate
Old 03-23-2010, 12:00 PM
Exactly. This was the only reason for my post.
Old 03-23-2010, 06:42 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
I think there was a guy on here that had them. He posted a while back, but they may have been the stage I heads.
Old 03-26-2010, 03:16 AM
LS6
LS6's Avatar
Even the flow is almost like a LS7 head, it seem not a lot have used the Stage 2.
I wish they have this kind for LS1 engine (5.7Liter).
Old 03-26-2010, 05:56 AM
Gordon0652's Avatar
Those flow numbers were on 4.125" bore @ 28"....
Old 03-26-2010, 07:00 AM
pink_bits's Avatar
i just had a motor build by Bryan from LME my heads are l92-ls3 they are 2.165" intake valve size, 1.600" exhaust valve size the tests are on 4.070 bore size at 28" water, and exhaust was with no pipe......
INTAKE
.100 .200 .300 .400 .500 .550 .600 .650 LIFT
82 157 242 292 345 356 367 371 CFM
EXHAUST
73 124 171 206 232 235 239 242 CFM
what do u guys think????
Simon
Old 03-26-2010, 08:03 AM
gnfan's Avatar
INTAKE
EXHAUST
Simon
Who's heads were they?
Old 03-26-2010, 08:34 AM
pink_bits's Avatar
they are done by LME.....
Old 03-27-2010, 01:07 PM
LS6
LS6's Avatar
I have done some search on the L92/LS3 CNC Flow chart, please see the attched PDF file.
Thanks...
File Type: pdf
Old 03-28-2010, 03:28 AM
LSWNDR's Avatar
Holy Mother ****** Batman.... Those heads are ******* nasty compared to all the other ones... If you decide to purchase a set of these post up your numbers because now i'm wanting a pair for sure the numbers at 600" are ******* crazy!
Old 03-28-2010, 10:29 AM
delphigto's Avatar
Two of my mustang buddies run tea heads and one runs there ported intake. They both make great power and have had good luck with them. Ive talked to tea and they are great to deal with.
Old 03-28-2010, 11:40 AM
LS6
LS6's Avatar
I have updated the PDF file and included the LME L92 CNC head part of the flow chart
From what I see from my self as flow chart, that TEA L92 Stage 2 CNC is leading, then WCCH Stage 3 CNC is after, but in term in acutal hp number when combined with the an engine and proper cam, the answer is "I DO NOT KNOW"
I wish I know or hear some one know...
Thanks...
Please see the below updated PDF file
File Type: pdf
Old 03-29-2010, 02:19 AM
LSWNDR's Avatar
Call up richard an talk to him because as many people as i've talked to on the phone he is only guy on here that will talk to you for 30 minutes when he is busy to explain any LS question you could ever have with all the right answers an he won't knock you for asking questions saying you need to pay him before you can get have any more additional information... lol I would love to see what kind of power they make as well...
Old 03-30-2010, 02:57 PM
mike c.'s Avatar
I spoke with Ed at trick flow and he told me they have a l92/ls3 head that had been in the works and should be out by the end of this year. I guess they flow like a 245head and they shrunk the large intake valve down to a 2.08 or 2.10. I also think he said it is a 11 deg head. Some where close to these specs. This head so i'm told will out flow some of the trick flow heads out now. This should be the next killer thing in the ls world and I can't wait to get my hands on them.
Old 03-31-2010, 12:37 PM
SLOC5LS6's Avatar
Thanks...
were those MAST LS3 numbers for small bore heads for LS1/6s?
Quick Reply: Has any one used the TEA L92 CNC Stage 2 heads
