LS3 cam choise.
.600 lift on both intake and ex.
238 243 with 115 lobesep.
Thanks!
//Henrik
that all comes into play when selecting a cam..the cam has to work with the rest of the motor as well as the gearing and type of tranny..it could be allright or it could be a dog..give us more info..
lobe seperation is just a by product of the correct valve events for a particular combo..
i know,splittin hairs,lol..
It´s a T56 and 3.73 in the rear with 25"-ish tires. (275/35-18)
Of course there are headers on (Super Comp 1 7/8")
100mm throttlebody and 100mm MAF.
Dual 3" exhausts.
It´s wonderful to read about your thoughts and reflections!
//Henrik
Dual 3" exhausts.
//Henrik
If your curious about what would work best cough up the 25 bucks and get PatrickG to custom spec you a cam and compare it to what you have.
The intake is a LS3 org.
And I´m not really in for dragracing. It´s suppose to be screaming around on tracks. Mostly sideways. Not just in a straight line.
Dual 3" exhausts.
//Henrik
And regarding changing springs sounds kind of strange. Of course the springs softens up after avile but are they really that bad?
The springs that´s in the engine by now are "single"springs that Lunati sent with the cam.
If your cruising it around and only wringing it out periodically then sure run the singles and check em as mentioned after a couple years perhaps.
