Main bearing clearance LSX Block
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
How much is a set of Clevite H series main bearings these days? $80-90? If you have a good crank grinder in your area, they will usually be able to grind .001" out pretty quickly for ~$60, and you also have nice round and straight journals. Not to mention, you can go ahead and check the ID of the rod bearings and have the rod journals ground for your desired clearance so that you don't have to go through this with them as well. IIRC, once you open the plastic wrap on those Clevites, you can't return them.
Only reason I am messing with it now is because I cracked an ATI hub and once it cracked it wasn't running true on the front of my crank anymore and a surface crack developed and eventually broke my Callies crankshaft. I was very luckily to not tear anything else up in my motor...didn't even spin the #1 main bearing where the crank broke. We checked my line bore and it was within a tenth of what it was the last time I put it together and all the other bearings looked perfect.
I got the .001x bearings tonight and I am at .0022 on the mains so I am happy with that.
