Need to line hone when switching from OEM main bolts to ARP main studs?
When looking for methods to reduce my cost on this LS3 motor build and keep it reliable, I started looking at staying with the OEM main bolts instead of going with the ARP main stud kit (which I used in my LS1). I've already decided to stay with the OEM bolts due to cost, so this question is more out of curiosity.
The LS1 was line honed when using the ARP's, and I found some conflicting information elsewhere on the forum. So, should you line hone when installing main studs? If yes, why?
On an LS block we typically don't see the main journal change with ARP studs, however bolts or studs on a virgin block the main journal is .0005" under our blueprint spec. IIRC 2.7508" is what we normally measure on a virgin block.
so to answer your question we line hone all blocks we build.
Kinda back from the grave with this one but, What happens when ya dont line hone them? Immediate failure or shortened life or just a chance at something or maybe nothing? With the motor out what does this usually cost? Thanks!!
Between main journal out of round and tight to begin with. Once it was line honed, measured .002" on the mains.
We charge $175 to line hone a block.
So since mine does spin, IE turn by using a ratchet on the crank bolt, it might be ok to go with it? Or is it a all out BAD idea? I hate the idea of taking this ****** back out.
Also when ya say 175 to do the work does that include removing anything? Would i have to hand you a bare shortblock? Or can it be a long block minus crank?
Thanks!
Thanks!
Thanks!
Thanks!
Damn. Thats what i get for expecting arp studs as standard. *******. When i talked to them about it afterwards when they said ohh well all our shop cars we use the stock tty bolts on as they hold up great. All i could do is sigh. Now that i tossed studs in and THEN found out that ya cant jsut do that i have to take the engine back out and disassemble it and then get it ****** honed. Just when i was thinking i had the initaitive to finish this ****** project. Oh well maybe next decade.
Was thinkin about it. When they built the engine would they have align honed it for the TTY's? IE since it was prolly not a new block, i just dont remember if it was as it was 5 years ago now, would they have align honed it just to freshen it up? I know it would have been to TTY bolt specs but just wondering. Also, and im putin alot on the wish list here, when i changed the bolts i took 1 out at a time and put the studs in and torqued them 1 at a time. Is there any chance that did anythign to help my situation?
I know i wont get any good news but im at that point where i was thinkin about doin the last bit of wiring and gettin really excited and now Im lookin at having to do alot more work to make this happen. And Im feeling a crying fit coming on.
Thanks to everyone who has been able to help me. Even if its not what i wanna hear.
John
John
i know this is not what you want to hear, but more than likely, and this is what i learned from class, when your using the stock fasteners, its not neccessary to align hone it unless it is out of wack. with a stud, its going to change the clamping force of the fastener itself. insted of the bolt pulling down on the cap, the nut on the stud is trying to pull the stud out of the block using the cap as leverege. basically putting the stress of the crank on the block insted of the bolt.
so, with that said, the fact that the block is essentially being pulled up and the cap pushed down, it really does do a number on ovaling the housing bores. its best to align hone it, even if it doesnt measure out of spec too much, or is just on the edge of being out of spec, once it heats up and gets some load on it, it will tend to push it further.
Oh well. Im on the phone with AZ speed and marine atm to get prices and schedule a visit. At least ill get to do soem needed cleaning of the engine bay that i was lazy about before. Make it tidier.
Thanks for all the help guys!
For your entertainment, 1 align-honed block + 1 six year-old kid:
http://www.youtube.com/watch?v=xMPDq4ica60
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
![Secret2](https://ls1tech.com/forums/images/smilies/LS1Tech/secret.gif)
