Stroker Motor questions
Please if you could let me know roughly the machine shop costs for building a stroker motor using a 6.0 block and the parts costs as well.
What I would like to do is build a 6.0 stroker motor. Im mostly interested in knowing what procedures had to be done and what to expect cost wise.
Im not really interested is assembly costs. I can assemble my own short block.
Do the blocks need to be clearanced for h beam rods?
What stroker kit combos are the best?
Machine work:
Bore/hone-$150
Hot tank engine block/heads-$45
Line hone-$120
Install cam bearings-$30
Pin fit align-$50
Resize used con. rods-$80 (not needed for this build)*
Mag/check and polish crankshaft-$100
Surface/mill heads-$50
Valve grind (performance 3 angle)-$145 (not needed)*
Install valve guides (16)-$90 (not needed)*
Install valve seats-$120 (not needed)*
CNC port L92 heads (intake, exhaust, chambers)-$600
* new con. rods, new heads so this price for machining labor was not necessary
Parts costs:
Stroker 4340 crankshaft-$600 new
Connecting rods (h-beam, 6.125")-$400 new
Pistons-$650 new
6.0L engine block-$200 used
L92 heads-$400 bare/new
L92 head valves Manley stainless-$250 new
0.660 lift valve spring kit-$290 new
Rocker arms, bolts/screws, support rails-$280 new
GMPP L92 4-bbl intake manifold-$320 new
I had started from scratch...
Good luck with your endeavor!
