Help an Aussie 6l cam l92 heads
The trick is maybe to look at the wider LSA options, as you are chasing top end power with high compression, it is highly advisable to maybe contact spinmonster at corvette forum he has some 116 LSA cams that are track and dyno proven on high comp LS3s, they are mid 230s intakes with over 600 lift with the high comp and wide lsa they work well considering they are on 114 ICL. They rev to the moon and it will also give you better clearance then a 108ICL cam.
The question I ask Paul is. Are you running the Higgins heads.. Do you have stainless valves? If so this is the issue go back to stock LS3 valves and problem solved mate...good luck
Big cam is back in and with correct pushrod length i have 95 thou clearence on intake and exhaust this is using feeler gauges and check springs, 95 is a bit tight on exhaust. I've cut 80 thou on exhaust so maybe another 10 thou req or 20 to make it safe
Hope this helps
So what was the go with the ptv issue....Pushrods to long, What lifters you using were the valves holding open or something? Shorter pushrods fixed it....pushrod checker is a must...
I am going to a 40 thou gasket in mine and 12:1 comp soon(32 thou quench yikes!). Now I have a single plain I will need to recam. My new springs arrived the other day. New cam in mind nothing to out of ordinary just f'n huge thats all lol...Nos plate goes on then.. Go the stock stroke I say Paul.
Just noticed a tick in engine and a pull down has a failed lifter, not any major damage. Looking at morels
