Help an Aussie 6l cam l92 heads
Old Jun 13, 2010 | 07:52 AM
Aussie 6L's Avatar
Default Help an Aussie 6l cam l92 heads
Hi all HELP!!!!!
I own a G8 ute with a 6l or L76 for you guys i had a 224/244 crane cam with all the good bolt ons 1 7/8 headers 3" exhaust FAST 102 and N/W 102 throttle body made good power 317rwkw's(sorry were in kw's not hp) in a M6 but decide go further. New comp lsr cam 239/247 114lsa with ported heads(flow 370cfm intake) milled 40 thou and the LSXR ported aswell. Yes big cam but this is a weekender with some trackwork fun and my daily has a 232/234 comp in a 5.7.
We'll the 239/247 .624 .624wouldn't fit due to PTV issues not even close i've now fitted a second hand 227/239comp lsr 112lsa .617 .624 and even with 80thou flycuts still won't fit i only have 10 thou on intake and 40 thou on exhaust. Looks like the heads have been milled to much only 60cc chambers
Any ideas on a lower lift decent sized cam that will fit, i'm running comp lsr double springs with there retainers.
Cheers for any advice
Old Jun 13, 2010 | 08:36 AM
Petraszewsky's Avatar
Yeah I'd say the same about the heads..That 227/239 cam is similar to the one I installed in my engine but my heads aren't milled.... Here's a short vid clip:
https://ls1tech.com/forums/generatio...3-cam-vid.html
Here's one you may be interested in:
the stats are at the bottom of the vid:
http://www.youtube.com/watch?v=HJrmB...eature=related
Old Jun 13, 2010 | 10:13 AM
thedak's Avatar
Good luck with .040+ taken off the heads.
Old Jun 13, 2010 | 10:28 AM
BORN2FLY's Avatar
How about a Comp LSR LSL 223/231 or the EPS tweaked version of the LSL lobe @ 222/230. It works great in my G8 with the heads milled .030, no fly cuts and oem head gasket. Results are in my signature below. Good Luck
Old Jun 13, 2010 | 10:31 AM
402GOAT's Avatar
^^^what he said. i see warpage in the near future
Old Jun 13, 2010 | 12:18 PM
Aussie 6L's Avatar
Thanks guys will dummy fit the other head and manifold to see if any issues there(if say 60 thou machined ther will be an issue there).
How can i measure how much has been milled off heads apart from measuring chamber????
Old Jun 13, 2010 | 01:12 PM
69LT1Bird's Avatar
Have someone measure a known stock head thickness and use some calipers and measure yours.
Old Jun 13, 2010 | 01:55 PM
AES Racing's Avatar
Overall lift isn't the issue, depending on cam specs, most often the issue is the intake opening, 240º duration with 110 ICL the intake will be opening 10º Before Top Dead Center, the piston is going up on the exhaust stroke, the exhaust valve is closing, the intake valve is opening before the piston is even at TDC, see the problem?
Max lift occurs when the piston is travelling down the cylinder on the intake stroke. So unless you have .900" lift you're generally ok.
Judging from the heads being 60cc, it looks like they were milled .048"
If you wanted to make a cam around the PTV issue, it would need intake opening at or after TDC and exhaust closing before TDC..... no overlap.
Old Jun 13, 2010 | 03:23 PM
garygnu's Avatar
get a EPS cam.
Old Jun 13, 2010 | 05:36 PM
Aussie 6L's Avatar
Hi Fraser Paul here or BLACKVE from LS1forum.
I understand your comments cheers.
The specs of my 227/239 are 8 degrees overlap intake opens 1 degree BTDC exhaust close's 7 deg ATDC. Specced from WCCH. 112 lsa on 112 ICL
It's just as the intake valve opens that there close so going to play with cam timing and see if that helps.
Thanks
Old Jun 13, 2010 | 05:59 PM
WKMCD's Avatar
You've got several problems here that are going to keep you from making good power. The first being PV clearance with any cam with more than a few degrees of overlap - if that. The second problem is going to be running enough timing with that much compression. Any cam that will fit is going to net extremely high cylinder pressure. These heads love timing. Best power seems to be made running 28-30 degrees of advance. I'd be surprised if you can get 20-22 before you run into serious knock. The third issue may be getting the manifold to sit down on the heads with that much milling.
Just my $.02
Old Jun 13, 2010 | 06:39 PM
Aussie 6L's Avatar
Just my $.02
Great 2 cents lol
I'm running 100 octane so comp should be fine. The PTV and manifold not so easy just about to start playing again
Keep the ideas coming
Old Jun 13, 2010 | 09:56 PM
frito1's Avatar
Flycut your pistons a little more
Old Jun 13, 2010 | 11:14 PM
Aussie 6L's Avatar
I just couldn't work out why i had such a PTV issue when others have been ok even with out flycutting.
Just worked out as i tighten rocker down its opening the valve even when on base circle of cam pushrods are way to long 7.350 thought they'd be close.
Of to by a pushrod lenght checker and do it right Dumbarse
Old Jun 14, 2010 | 03:55 PM
AES Racing's Avatar
What did you use to measure PTV? clay?
I normally use an adjustable pushrod and checker springs.
Old Jun 15, 2010 | 07:10 AM
super6ute's Avatar
Hey Aussie 6L,
I have fitted that exact cam to a few LS3's and had around .080'' PTV on the inlet from memory.
My suggestion is get some new stock heads, .040'' gaskets and keep that cam. You may be suprised how cheap the bare castings are.
Old Jun 15, 2010 | 07:58 AM
WKMCD's Avatar
Originally Posted by super6ute
Hey Aussie 6L,
Agreed!
Old Jun 15, 2010 | 10:44 AM
69LT1Bird's Avatar
http://sdparts.com/details/gm-perfor...parts/12615361
Old Jun 16, 2010 | 03:29 AM
Aussie 6L's Avatar
Yep used clay and dial indicator to check with checker springs.
Got a pushrod checker tonight so with shorter rods the big cam should be back in soon.
Hey Aussie 6L,
I want the comp up for dynamic compression so i'll stick with the ported one's for now. Dummy fitted manifold and fits well.
Old Jun 18, 2010 | 01:05 AM
hymey's Avatar
I had 36 thou off heads, stock gaskets, with a 240 intake lobe I had 120 thou ptv clearance on 160 thou reliefs so 40 thou interference on a 108 ICL.
The question I ask Paul is. Are you running the Higgins heads.. Do you have stainless valves? If so this is the issue go back to stock LS3 valves and problem solved mate...good luck
