ls1 to ls7 coils? do or dont?
Old 07-15-2010, 07:23 AM
ajw2500hd's Avatar
Exclamation ls1 to ls7 coils? do or dont?
if i have a 98 camaro and installing a ls7 is it a good idea to get a set of ls7 coil packs or stick with my ls1 coil packs? thanks aj
Old 07-15-2010, 09:57 AM
LS1TECH & Trucks Sponsor
Sales4@Texas-Speed's Avatar
I would stick with your stock LS1 coils. The LS7 coils have a different mounting pattern if I remember correctly. If you are looking for a stronger coil you might look into the truck coils.
Old 07-15-2010, 11:18 AM
AES Racing's Avatar
LS2 and LS7 coil packs are same, have more kV output then LS1 coils.
Old 07-15-2010, 01:14 PM
Petraszewsky's Avatar
I would go with the LS7 coils...Maybe not quite as much output as the D585 coils but still better than the LS1 coils...JMO
Old 07-15-2010, 01:18 PM
95wannabe's Avatar
D585...is that the truck coils?
Old 07-15-2010, 01:36 PM
^^^Yes...Cylinder shaped like the LS7 coils ( can't remember part # for LS7's off the top of my head) but they have aluminum heat sink fins at the top of them...
Old 07-15-2010, 01:39 PM
AES Racing's Avatar
D514A for the LS2/LS7 ignition coil
Quick Reply: ls1 to ls7 coils? do or dont?
