L92 heads?
Old Jul 25, 2010 | 11:33 PM
Quick99TransAm's Avatar
Default L92 heads?
Ok right now i have 2.5 5.3 heads on a lq4.My questions is it worth it to swap to L92 heads.I think the l92s will give me room to go but what do you guys think?
Old Jul 26, 2010 | 05:36 AM
firebird99's Avatar
The guy i just bought my shortblock from has a set half ported with springs tit ret. valves everything plus intake with rails injectors,tb for sale if your interested all brand new with reciepts let me know ill get you his number
Old Jul 26, 2010 | 10:09 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
The only issue with putting the L92's on an LQ4 short-block is the compression drop. You're going back down to about 9.5:1 static compression or so (before milling and thin gaskets of course). What camshaft are you running?
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Jul 26, 2010 | 10:35 AM
Default heads
I have a stock cam for now but was thinking about the 228r.But i have herd that l92"s like split duration cams.
Old Jul 26, 2010 | 11:13 AM
With that compression, and depending on which bolt-ons you have exactly, I'd consider our Texas Speed 225/230 LS3 cam or similar!
__________________
Old Jul 26, 2010 | 04:39 PM
mike c.'s Avatar
save the money and buy a set of trick flow heads. You will gain more and have a better product.
Old Jul 26, 2010 | 05:14 PM
Default Cam
Car has full intake and full exhaust.Matt how would i use that cam in my set up would i have to swap to an ls2 front timing cover so that the cam postion sensor will work
Old Jul 26, 2010 | 06:18 PM
SweetS10V8's Avatar
Im pretty sure that LS3 aftermarket cams still have the rear cam sensor pickup on the camshaft.
Old Jul 26, 2010 | 10:24 PM
tspence45's Avatar
All you have to do is tell them what application the cam is for, and they'll set you up with what you need. Because I have their 231/236 cam for an LS3/L92 in my LQ4. They'll just have it ground on a Gen III 3 camshaft, instead of a Gen IV.
Old Jul 27, 2010 | 09:20 AM
When you order, we just indicate it is a 3 bolt cam core and everything, including the stock location cam position sensor, will work perfectly!
__________________
Old Jul 27, 2010 | 12:44 PM
Default cam
What do you think about this cam for my set up 240-246-.600-.600-114
Old Jul 27, 2010 | 03:00 PM
thedak's Avatar
Way Too Big
Old Jul 27, 2010 | 03:15 PM
402GOAT's Avatar
id be looking at a custom grind. l92's flow well enough that it takes a short duration cam to make most power.
Old Jul 27, 2010 | 04:11 PM
WKMCD's Avatar
I don't like a single one of those numbers for the L92 heads.
Old Jul 27, 2010 | 08:46 PM
Default heads
What do you guys think is it worth the swap or stick with the 2.5 5.3 heads
Old Jul 29, 2010 | 04:48 PM
Fourman's Avatar
mine is 234/242 .598/.593 114 and i made 523WHP and 468WTQ peak with >400lb/ft from 2800-6700rpm. i think the last 3 numbers are fine... with 39 more cubes anyway.
dont overlook what Matt said above about compression... personally i think youd be putting a lot of money in while getting very little out. in addition to the heads, you will need a new intake manifold so get ready to do the 'full intake' again. The heads will flow a ton but with the killed compression i think you may come out even on power and possibly down on torque with those huge gaping intake ports killing velocity.
Old Jul 29, 2010 | 05:43 PM
Default heads
was planning on milling the heads and running thin head gaskets even if i got compression to 10 to 1 would it be worth it.
Old Jul 29, 2010 | 08:06 PM
Fourman's Avatar
LQ4 pistons have a dish, right?
watch getting a big cam anyway... my cam did not have enough clearance with my LS2 bottom end unless my L92s were unmilled and using a GM .052 gasket
good luck
Old Jul 29, 2010 | 09:21 PM
Default lq4
Correct Fourman LQ4's have a -8cc dished piston
Old Jul 30, 2010 | 10:04 AM
1SLwLS1's Avatar
good luck
They may be a dish, but they don't have valve reliefs so as stated, check your PTV again.
