what are the best hyd lifter to use in a rhs block
Old Jul 31, 2010 | 12:01 PM
mitch g's Avatar
Default what are the best hyd lifter to use in a rhs block
and part #please
Old Jul 31, 2010 | 12:10 PM
Steve1969LS1's Avatar
Im using the COMP hyd vertical bar lifters.. let me go get the part number
Old Jul 31, 2010 | 07:04 PM
Shawn @ VA Speed's Avatar
I use the lunati tie bars.
Old Jul 31, 2010 | 10:01 PM
SweetS10V8's Avatar
Comp short travel lifters 15850-16
Old Aug 1, 2010 | 11:20 AM
racer7088's Avatar
I would use the Morel link bars probably including the Lunatis like Shawn said. The Comps would probably work as well but I have not used those yet.
Old Aug 1, 2010 | 12:24 PM
Marble_Sharp's Avatar
Any benefit to the Limited Travel Link Bar Morels, other than them costing another $100?
Old Aug 1, 2010 | 03:37 PM
racer7088's Avatar
Not unless you are running much higher spring pressures and can set preload very accurately.
Old Aug 1, 2010 | 05:46 PM
musclecity85's Avatar
how are the Morel "STREET" Hydraulic Link-bar Roller Lifters compared to the normal link bar lifters? i noticed there only 375
Old Aug 2, 2010 | 03:11 AM
racer7088's Avatar
I do not think these are any relation to the other Morel lifters and I haven't seen a picture of them yet?
Old Aug 2, 2010 | 04:34 AM
bigsticksupra's Avatar
http://www.lunatipower.com/Product.aspx?id=2533&gid=310
are the 72532LUN the ones you would use? what series of the Morels would these be comparable to? and morel or lunati for the best lifter? thanks
Old Aug 2, 2010 | 12:05 PM
racer7088's Avatar
I think that is the fancier High RPM micronited model which is more expensive.
Old Aug 2, 2010 | 01:23 PM
i use the 72332 for most stuff and the 72532 for higher spring pressure stuff like big lift or forced induction
