Which of these 3 cams would you use?
Old Oct 13, 2010 | 02:39 PM
  #41
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
As an update: I received an email from one of the higher ups at Comp Cams and the situation was explained/clarified for me. Those lobes are Geoff's and Comp was not supposed to have let anybody else use them, but it apparently was being done and slipped by somehow. I have removed them from our custom grind lobe list already.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Oct 13, 2010 | 06:28 PM
  #42
Neumonic2002's Avatar
What happened to all the other posts?
Thanks for clearing all that up Matt.
Old Nov 13, 2010 | 05:01 PM
  #43
As an update to this thread:
I am really close to pulling the trigger and think after much research and help from several people posting an all LSL lobe cam might be a real nice stick along with the comp 26926 springs.
231/235? .617/.621
Or
235/239? .621/.624
Anybody run either of these in an LS2?
Old Nov 19, 2010 | 12:29 PM
  #44
bortous's Avatar
Default Which camshaft?
Hi. I have an ls2 which has the l92 heads with headwork and 12:1 compression that is currently being installed.
I was considering spin monsters camshaft 230/236 .629 .641 114lsa
Luckily enough my tuner recently tuned dumthree ls3 powered vehicles dumwith that same camshaft along with a fast intake and nick Williams 102mm throttle body along with headwork and compression bump.
That car made 494rwhp which is excellent.
After looking at the dyno curves the power drops off very quickly after 4700rpm.
Now, I'm getting the lingenfelter gt1-1 camshaft which is a 229/242 .631 .631 114.5lsa
This cam was also installed on an ls3 with the same work as the other one mentioned except it had a ported stock throttle body.
This car made 511rwhp and about 20lb/ft more torque.
The torque curve was very interesting.
From below 3200 the car made about 8hp less than the spin monster cam, but from about 3400 the lingenfelter made more power and it kept increasing till the red line without cutting off.
Now, there is a lot of negatives about wide splits but this lingenfelter cam worked extremely well.
Dunno, maybe lingenfelter know a thing or two.
What do you think of lingenfelter cams? I'm
Cheers
Old Nov 23, 2010 | 09:07 PM
  #45
Just wanted to let you guy's know which cam I went with:
Comp 235/239 .621/.624 112+4 with the comp 26926 springs.
My Underdrive Pulley is on back order till Dec.6, should have results a week or two after I get all the parts.
Old Dec 21, 2010 | 09:09 PM
  #46
JayplaySS's Avatar
Moderator
I missed this thread somehow..
John, let me know what your outcome is, please. I am between Pat's 234/242 and another on as well as the Tsunami but on EPS lobes...I'm all over the place.
Old Dec 21, 2010 | 11:48 PM
  #47
ramairws6's Avatar
And what lobe/lobes are we speaking of??
Old Dec 22, 2010 | 10:52 AM
  #48
JayplaySS's Avatar
Moderator
He's referring to Geoff's EPS lobes, only available from Engine Power Systems.
