how much cubic inch can you get out of a 6.0?
#61
My 6.0 iron block was filled up to the water pump ports with Hard Blok for stability and bored to 4.07". I would not feel comfortable boring one any farther than that without significant sonic testing. And only with a shorter crank than the 4.100" I am using to minimize side loading the cylinder wall between bottom dead center and the middle of the stroke.
#62
Is the iron 5.3 is the same as the iron 6.0 in terms of the water jackets between the cylinders walls?
If yes, then l would make an experiment to bore the 5.3 iron block to 4.06"...
With in my area there are a lot of 4.8 & 5.3 iron blocks
#63
The 5.3 iron blocks have more water between the cylinders on the ones I have seen. You can bore them to 3.900 but 4.000 would probably not be anything I would run.
