These are the parts I have so far, Cam Gurus come in please....
I have a
1. scoggin l92 416 short block with -2cc valve reliefs
2. LPE ls3 cnc'd cylinder heads that flow 348cfm and 229cfm at .600 and 352 cfm and 232cfm at .650
3. I also have a vic jr intake that will also be ported and a ultra low profile edelbrock elbow (I refuse to cut my car, I know I will be leaving a little on the table) and using my UMI 90mm TB.
4. I will be 11.8 -11.9 on the compression
5. I will be running a comp cam 247/259 112+2 with .625 lift on both sides using LsL lobes, this is a cam that comp spec'd me out.
6. All using a set of Yella Terra RR's.
My goals are getting in the 550 rwhp range, what do you guys think?
Go easy please
Go easy please
that elbow is crap everyone keeps telling you this. if you put that junk on your motor then there is no point to using the intake you are using. hell may as well put the ls1 with heads and cam back in. You need to look more into your setup i think your going at this in a rush and your over looking some key parts in your setup Zeke. i Would use fast 102 because your setup is going to be in the fast 102 power band setup and i have seen nice numbers out of them. Dont get cheap and skimp on things now your already this far take the time and do it right bro.....
I see, I didn't have a clue that people were so split on the elbow! Doing research on it and I called alot of shops I might add, some BIG shops said I'll be fine others said absolutely not. So it looks like it's going back to summit and I'll be saving for that FAST, cause I don't wanna leave it to chance. Hell I got 5 months til spring LOL!
