need help with stroker 4.100" crank combo
Old Nov 17, 2010 | 04:30 AM
allan808's Avatar
Question need help with stroker 4.100" crank combo
well i picked up a 4.100" crank and was planning on useing 6.125 rods, the question is what size pistons do i use? i want 11.0 comp and ill be useing l92 heads..
what kinda cubes can i get with this crank in a lq4 or lq9 and id like to hit it with some nitrous..
experianced guys chime in please
Old Nov 17, 2010 | 10:03 AM
1CAMWNDR's Avatar
Contact Brian Nutter from Wiseco Pistons. He helped me a great deal on my pistons for a 6.0L 4.07" bore, 4.100" Compstar crank and Eagle 6.125" rods. He is a member on this site, screen name is: briannutter .
Good luck. Oh, if you plan to use nitrous, I'd stick to a 4.03" bore. That is 418".
Old Nov 17, 2010 | 11:51 AM
Callies Performance's Avatar
^^looks like a custom piston, i would contact Wiseco or Diamond.
Old Nov 17, 2010 | 01:11 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Wiseco offers a +3cc dome piston, which with the GM MLS gasket and a 70cc chamber would net you about 11.6:1. That, with the right cam and tune, could still be very pump gas friendly. OR, their -11cc dish, with a .040" gasket and milling the heads down to about 63cc would net you 11.0:1 static compression. I can get you into either piston set (which includes a steel top/napier 2nd ring set, coated skirts, etc) for $759.99 plus shipping!
Not really enough info to tell, but those were likely their shelf-stock K450X7 or K454X7 pistons
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Nov 17, 2010 | 02:16 PM
1CAMWNDR's Avatar
Yes, they were a shelf piston......not the newest series, the last one. K-450X7 I think.
Old Nov 17, 2010 | 03:46 PM
10.4 Glad you found one
Old Nov 17, 2010 | 06:26 PM
melsie68's Avatar
http://www.wallaceracing.com/Calculators.htm
This site has some useful calculators for just about any inquiry on a build.
Old Nov 17, 2010 | 09:44 PM
allan808's Avatar
thanks guys,matt ill be contacting you soon on some pistons!! i got 1 more question for you guys... been looking at a set of rods that i wanna pick up need to make sure itl work with my crank,heres the specs...the crank i got should work with stock size bearings..whats a safe bore on the 6l block for nitrous?
thanks
GRP Billet Aluminum Rods
All caps and rods are both numbered 1-8 and include 7/16" ARP bolts.
Center to Center: 6.125"
Pin Diameter: .927"
Crank End Diameter *without bearings*: 2.220" (for 2.1" bearings)
Pin end width: 1.064"
Crank end width: .941"
Old Nov 17, 2010 | 09:47 PM
KCS's Avatar
KCS
Moderator
Aluminum rods...and L92 heads? Why?
Old Nov 17, 2010 | 10:42 PM
AES Racing's Avatar
Chances are those aluminum rods won't fit the block, won't fit the cam, won't fit the pistons. Theirs a couple things you can do before ordering to help make them fit, like 1.888" rod journal, 3/8" rod bolts kinda help but seems they don't change the dimension of the rod with smaller bolts. Raised cam helps.
Then look at the "above pin" thickness, if its anymore then .250" it won't fit a shelf wiseco.
Old Nov 17, 2010 | 11:36 PM
allan808's Avatar
Then look at the "above pin" thickness, if its anymore then .250" it won't a shelf wiseco.
i was just wondering if itl work,i could get em for cheap..
looking for some h beam rods whats good? and part numbers,thks
Old Nov 18, 2010 | 12:15 AM
AES Racing's Avatar
If you're building it yourself i'd suggest compstar rods, need the least amount of work compared to other brands (ie Eagle). Closest you will find to a rod being ready to install out of the box.
Old Nov 18, 2010 | 09:20 AM
I agree with Frasier, the Compstar is hard to beat for a fairly budget oriented rod! They also have a bit better clearance to pan and other rotating parts due to their design!
__________________
