Callies LSC cranks
Anything in particular you need?
I bought it mainly because the 4340 forgings are overkill for what I do (550hp NA motor)
Not saying its guaranteed to those power levels, we've had some people test the ragged edge with these no issues.
Normally with a compstar crank and rod combo, you will get the original compstar good to a nice amount of HP.
Per Callies, I believe these "C" series 5140 cranks were originally rated to about 650 HP.
Per talking to Callies today, they are now rated at 750-800HP. Not too shabby for some "budget crank".
I'll check the rod journals tonight.
Once cleaned the crank looks even better than in the pictures above. Mirror finish everywhere.
Main journals are all within 2.5592~2.5593 with none beyond 0.0001" out of round.
Runout on center journal is less than 0.0006"
Runout on rear seal journal is also less than 0.0006"
Rod journals all measured 2.0992~2.0993 with none beyond 0.0001" out of round.
For a "budget crank" the machining is excellent.
Upon further inspection I did notice that someone, somewhere did drop the crank on a hard surface and dented the side of #8 rod journal. Not too happy about that but I don't think it will be an issue but I will show it to my machinist when I get it balanced. I'll see what he says.
I'm posting this since info on the LSC crank is hard to find.
The H1 bearings are simply too tight for my build ( I got on average 0.0003~0.0005" clearance with them).
