what compression will i be running. -19.2 dish pistons
Ok im building a ls2 and i ran across a good deal on some pro select diamond 4.010 - 19.2 dished pistons. stock stroke 6.125 callies rod. what compression give or take will i be running with 243 heads or 317 heads thanks
Im running a d1 procharger with 3.4 pulley.. the 243 will be close to stock..just a clean up if any. 64 cc i believe and 317s run 70-72 cc but i can have them milled to be just right. and gaskets close to stock.. im open at this point.
try this site once you get all the pieces to the puzzle and plug them into the calculator.
http://www.wallaceracing.com/cr_test2.php
LS1Tech Premium Sponsor
With a GM MLS gasket and the 64cc LS6 heads, you'll be at about 9.1:1 static. Throw a .040" gasket on that same combo and it nets you 9.3:1 static. With the GM MLS and the 72cc 317's, you'll net 8.5:1 static. Throw the .040" gasket on and mill the 317's to 70cc and you net 8.8:1 static.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
