Vvt mast ho cam
Vvt mast ho cam
hey guys im from the performance trucks side.. ive got an 09 gmc sierra with the 6.2 all mods in sig., im wondering if anybody has a video of what the vvt ho cam sounds like or any info on performance and etc..? that is the cam my tuner wants to put in my truck and said gains are well worth it and he has used them alot in applications.. also any input on rockers, pushrods, or whatever would be appreciated as well.. he told me since its not over 600 lift he doesnt worry bout pushrods and that the stock rockers work just fine all i need is cam phaser and springs..
That is the same cam i am interested in running in my 08 denali 6.2, did you find any clips or responses that are of any help to your decision. I am thinking the same as your tuner on the rockers, but i already have purchased valve springs, and i plan to buy a set of pushrods, just for insurance.
MAST HAS THE L92 HO ENGINE INSTALLED IN A OLDER PICK UP AND THEY HAVE A QUICK START UP IN THIS VIDEO, BUT NOT A REAL FOCUS ON THE ACTUAL SOUND OF THE CAM, BUT MAYBE THIS HELPS A BIT. JUST WHAT I HAVE FOUND. I SEE A FEW GUYS WITH L99 ENGINE SAYING MAST STAGE 1 BUT IT DOES NOT GIVE THE SPECS TO KOW IF IT IS THE HO OR THE SS CAMSHAFT. MAYBE YOU HAVE FOUND SOMETHING ELSE
http://www.youtube.com/watch?v=L79rl...eature=related
http://www.youtube.com/watch?v=9MAsy932KBU&NR=1
Hope that helps
check this article, it is proof of the potential of vvt, with aftermarket camshafts.
http://www.gmhightechperformance.com...all/index.html
Back to the MAST MOTORSPORT camshaft, I have tried calling MAST for the last past week, to order this HO camshaft for my truck, and I have got nothing but voicemails, I have talked with someone only one time to be told that they would have Chris call me, NEVER HEARD FROM HIM SINCE MONDAY 1/4/2011, I have left 2 voicemails, and plenty calls through out this week. All this said, I think I am taking my business elsewhere, I called Comp and got a recomendation and will probably purchase one of their VVT cams and the phaser kit on Monday.
You need to make sure you do not have AFM. If you do, you need to remove it before you upgrade your cam.
You also need to call your dealearship, with your vin, and see what "cam actuator" part number is. There are two vvt limiter kits and two different cam cores, both depend on the part number of your cam actuator. (See below)
Heres an article on Comps VVT cam and its gains. (+70hp with no losses becasue of VVT)
http://www.gmhightechperformance.com...les/index.html
________________________________________
Tech Bulletin – COMP Cams®
RE: GM Gen IV VVT Cam Core, 156 family and new 189 family introduction
Summary: GM introduced a second style VVT cam actuator (aka phaser) in 2007, and ran two different cam actuators through 2007‐2008+. The new style became the exclusive unit in most 2009+ engines.
Original (old style) GM PN 1258994: 2007‐2008 (uses cam core 156‐)
Current (new style) GM PN 12606358: 2007‐2009+ (uses cam core 189‐)
The difference in camshaft core is the pin to centerline position. The difference in pin between 156 and 189 equates to 13 degrees cam retard (if a 156 is used where a 189 is required).
I am about 98 % sure my truck is not a AFM/DOD vehicle, just VVT. I do not think they had these L92's with DOD, I could be wrong but I think they all were just VVT.
THanks again for the heads reminder I had seen the bulletin from comp, and that earlier stated article on gmhtp.
? Well that sounds pretty trick honestly. But I'm old school and stuck with this statement from a wise old racer. "Power comes from three things: Cubes, heads, and lobes on the cam." It seems redundant and sorry for hi jacking the thread but respectably duration on any cam lobe will put you with wide margins of power. I think I'm just venting though because I tuned a VVT cam using the phaser features on HPT and it was a ******* nightmare to not get it to fall on it's face after 4500..... I wish you the best of luck though!
Oh and an easy way to check if you've got AFM, look at your brake booster on the underneath side and see if it says AFM. The L92 is a 6.2 Litre engine most commonly manufactured without AFM, however in 07+ applications could be exclusively ordered like that however sacrificing some odd ten horsepower due to the smaller cam and increased valvetrain stress due to those ridiculous colapseable lifters.
For now the best contact method is by email! If I can do anything to help from this point on feel free to email or PM me!
Thanks
