milling l92 heads
Simply decreasing the volume in the chamber by flat milling, should have no relevance to port flow, or flow past the valve seat curtain area into the cylinder.
I could be wrong, and if so , please go into detail about why I'm wrong.
Thanks
thats why as heads get larger valves or go up in runner size,(for ex tfs heads in 220,235,245 etc)you generally see an increase in chamber size and bore adaptors used to flow them which all help to unshroud the intake valve as much as possible
its amazing when you move a head over one way or another, on a flow bench the results you sometimes will see
Are you saying the flow is effected only if the head milled vs. being cast with a small chamber?
My understanding is that small chambers have better short turn flow.
