6.0 370 500hp?? what do u think?
Ok my ls1 decided to take a dump i had the polluter cam from tick performance in it and LOVED it!! very awesome cam IMO and i street drove it alot!! well i had a lifter stick and it trashed the cam rockers block and 1 piston.... SOOOOO i pulled the whole LS1 out and am wanting to go with a 6.0 LQ9 or LQ4 i am told that my crank out of the LS1 will fit into the new 6.0s thats my first question is what years of the lq4s can everything swap right over in to my 02 camaro from my LS1. so with that said i was just gonna get a bare block, bore it to a 370 clean my crank up a little and maybe go with a set of eagle or scat 6.125 forged rods and im not sure what pistons, im wanting high compression but still want to run 92 octane i have a friend porting a set of 799 heads for me also. i really liked the polluter cam and was wanting to use it again or something VERY close to it (liked the power and the thump) this car is not a drag car and will hardly see the strip but a few times mainly a street cruiser on the weekends its 6spd with the **** 10bolt still with 4:10s
So im really looking for close to 485-500rwhp on motor do you guys think it can be done with the set up?
LQ4 bored to 370
ported 799 heads
11.5:1 if not higher compression on 92octane pistons
forget 6.125 rods
polluter cam (242/242 dur. 610/612 lift)
LS6 intake
longtubes
ive looked on here for 6.0 builds but cant really find anything close to what im wanting to build i dont know if im just retarded or what but i cant find any good 6.0/370 build threads if you know of one but a link up and i would love to check it out
Thanks alot for any input fellas!!
LQ4 bored to 370
ported 799 heads
forget 6.125 rods
LS6 intake
longtubes
well i was going to go with the iron block cuz my ls1 block is bad... and i was probably going to spray it eventually so basically just strength and i can pick an iron block up for cheaper money is kind of an issue im only going to have 1500 maybe 2000 for everything (block, pistons, rods, rockers, cam, lifters) and all the gaskets and bearings im cutting it close i know but i dont think ill have the money for a stroked 402 or 408 crank im trying to go the cheapest rout possiable without going to a 402 if i could get 480hp i would be pretty happy tho. idk i was just seeing what everybody on here thought if it could even be done or if im just shooting for the impossiable for what im working with haha
Dont think youll hit 500 but it should be stout. Im not sure why everyone makes such a big deal out of a aluminum block. For the 70 pound difference when most guys are just building street cars any ways.
Good luck
Good luck
Good luck on the budget, let us know when you blow past it, I'll guess triple that budget. Then double that... I thought my stock internal ls3 would cost that much...
But like they said. On a 6.0 you'll need tea, tfs, some big name potted head, a fast intake, a better cam, you could do ls3 heads but it would take nice supporting mods to do it..
My old 370CI made 494RWHP through an automatic and still had a little left in it. I think it would have seen 500-515 to the tires if we would have tinkered with it more.
It's very do-able. Here's my old thread. You'll have to go through the pages because we did a lot of changing things up through out the build.
https://ls1tech.com/forums/drag-raci...-ci-build.html
The following users liked this post:
gomeezz_1 (04-10-2023)
thanks for letting me know but as of right now im waiting on cash hopfully have it within the next couple weeks and ill let u know when it comes time for me to buy pistons
