Scat or Manley Crankshaft?
BTW do not let "Made in China" through you off, reason stuff is garbage their is because the engineers in the US make them use cheaper metals to keep cost down. Example Piston 2618 alloy here is the same compound as in China.
-Adam
-Adam
Well not sure but ive seen the magnum well over 2000hp. which is is pretty much the same as dragonslayer.
The few more dollars for the dragonslayer is well worth it. very nice crank plus resell value is alot more. (side note also helping keep jobs in US)
