Are ls2 and ls7 push rods the same length?
Old Mar 11, 2011 | 12:27 PM
firehawk68mcleod's Avatar
Default Are ls2 and ls7 push rods the same length?
Heres the deal im building an ls2... and i figured i would upgrade to the ls7 lifters after hearing everyone has had good feedback on them. but i already purchased ls2 texas speed push rods.. just wanted to make sure there the same length... let me know thanks
Old Mar 11, 2011 | 01:11 PM
ChucksZ06's Avatar
ls7 are quite a bit longer...I went with 3/8 for stiffness.
Old Mar 11, 2011 | 01:30 PM
speedracer2536's Avatar
The lifters are the same as the ls2.. Your ls2 pushrods will be fine
Old Mar 11, 2011 | 06:48 PM
MAD DOG 20/20's Avatar
Correct...on both.
Old Mar 11, 2011 | 09:16 PM
Is there anything better bout the ls7 lifters
Old Mar 11, 2011 | 10:45 PM
ChucksZ06's Avatar
Ls7 pushrods are not the same as ls2. Bad form guys. The lifters are interchangeable but the pushrods are aproximately .500 longer. This is why it is useless to try and help people on this forum...You guys cannot even READ! Read what the op wrote before you give half-assed advice.
Old Mar 12, 2011 | 12:57 AM
Thanks ... and good advice... Do you happen to know why the ls7 lifters are better than ls2s thanks
Old Mar 12, 2011 | 08:06 AM
ChucksZ06's Avatar
I have used all the lifters interchangeably in ls engines...ls1, ls2, ls7 and the truck lifters are all good...but I disassemble each lifter and make sure they are ok. The same is true for the oil pumps. Lots of disinformation on the internet as most people just pass on what someone else tells them rather than fiquring out themselves. Good luck with build.
Old Mar 12, 2011 | 08:58 AM
WTF are you smokin man.. The LIFTERS are what he is asking about.. The ls2 pushrods will work in his LS2 with LS7 lifters.. Just like i said..
Old Mar 12, 2011 | 04:12 PM
Do you happen to know whats the differance between ls2 and ls7 lifters performance wise? thanks
Old Mar 13, 2011 | 12:24 AM
hibchr's Avatar
gm part #17122490 is the same lifter for ls2 and ls7.. Theyre is no difference.. So you would use the ls2 pushrods..
Old Mar 13, 2011 | 10:01 AM
SOMbitch's Avatar
BINGO we have a winner All GEN III/IV motors use this lifter
Old Mar 13, 2011 | 10:11 AM
ChucksZ06's Avatar
This was the op's question...I cannot read anyone's mind...apparently you stoners can and somehow know that he really did not mean what he asked. If op is using ls7 heads he would need to know that they use longer pushrods. I am sure you guys are right and knew that he really did not mean the question the way it was asked. I give up.
Old Mar 13, 2011 | 10:47 AM
KRAZY K 2000 TA's Avatar
i was confused for a minute too, i thought he asked if the pushrods were the same length? which they are not.
Old Mar 14, 2011 | 08:47 AM
That was the thread title but it boils down to the lifter..
Old Mar 15, 2011 | 02:02 AM
MotoFreak's Avatar
LS7 lifters! good!!
