(help)compression ratio
Old Jun 21, 2011 | 08:04 PM
billyflantos's Avatar
Default (help)compression ratio
what would be my compression ratio be...its a -4cc flat top piston with ls3 heads milled .040 with a .050 head gasket....this is a 408 motor....thanks
Old Jun 21, 2011 | 08:49 PM
sandragnx's Avatar
408=4.030borex4.00stroke,ls3 head milled .040=64cc chamber.My guess=11.7 to 1
Old Jun 21, 2011 | 09:58 PM
Dazzak75's Avatar
Can you work out mine for me too?
LSX 454 standard pistons with valve reliefs, head gasket .051, LSX heads ported and shaved .040.
I am unsure of what the compression is, I have heard approx 11.5:1 or even 11.8:1.
Old Jun 21, 2011 | 10:17 PM
xdanny510x's Avatar
I got same set up as u 408 i got 11:8:1 i could be wrong
