Fresh engine problems
Bore sizes?
piston sizes and brands?
what kind of rings are you using?
how is your PcV setup?
who built it?
how did you break it in?
what oil are you using?
What brand crank n size stroke?
What kind of oil pump?
Bearing clearances?
Anyone else?
Did I leave something out lol?
But anyways, I did not build the engine, it was fresh in the car when I bought it, engine short blockwas built in az at basko engines So the recie
But anyways, I did not build the engine, it was fresh in the car when I bought it, engine short blockwas built in az at basko engines So the reciept says... Built in january 2011, eagle crank and rods, diamond Pistons. Stock 823 heads with patriot extreme springs and comp valve train, stock intake... That's the gist of all I know... Any help would be much aprichated as I'm newish the the ls world
So with that said, I have considered both of your suggestions which led to a cyl leak down and a compression test. Results: all cylinders had 10 percent or less cyl leakdown and compression was 190-205 psi on all cylinders.
Here are my questions:
1. what oil should I be using
2. what weight oil should I be using
3. What checks do I need to do to solve this problem
Any help would be much appreciated,
Thanks
1. Leak down test
2. Pull plugs and look for oil on the spark plug. Could be valve seals if wet.
3. Inspect crankcase ventilation. A catch can helps but also replace the oil cap with a breather.
20W50 is a heavy oil that I would only run if I was getting low on oil pressure. I always run a 10W-30 and 10W-40 mix.
Just my .2
