Piston offset question engine building advice please
Old Jul 3, 2011 | 02:46 PM
06chevy5.3's Avatar
Default Piston offset question engine building advice please
so here it goes I have a set of foreged wiseco pistons that i sent to the machine shop to be balanced when i got them back he put them in a box with numbers indicating which piston is which number.... I think??? but shouldn't all the pistons weigh the same if its balanced and not matter which piston goes where???
So i went to assemble the engine yesterday Wiesco being offset pistons have a dimple thats supposd to face the front of the engine well 2 of them are wrong if i install the pistons in the cylinder number indicated on the box cylinders 5,6,7,8 the dimple faces the rear. but the valve reliefs line up
So should i just ignore the numbers on the box and install them according to the dimples or send them back to be rebalanced?????
Old Jul 3, 2011 | 07:11 PM
Firehawk441's Avatar
That is correct.
Old Jul 3, 2011 | 07:31 PM
KCS's Avatar
KCS
Moderator
Balancing has nothing to do with which cylinders the pistons go into.
You may want to call your machine shop and clear this whole thing up.
Old Jul 4, 2011 | 12:00 PM
06chevy5.3's Avatar
Not open for another day the engine is all together and im pretty sure he just gave me a piston box marked from a previos job and everybody is telling me to ignore those numbers
Old Jul 4, 2011 | 03:35 PM
KCS's Avatar
KCS
Moderator
Out of curiosity, did you have this machine shop hone your block for these pistons or at least check to see what the piston-wall clearances will be?
Old Jul 5, 2011 | 09:51 AM
ChucksZ06's Avatar
This is why there are so many problems with engine building and bad things happening. If the machinest was any good each piston is fitted to each bore and each piston/pin/rod combo is balanced to the crank. So you just throw it together because you were confused about the forward marks on the piston. It probably will not matter because something more drastic may be in store for this engine. If something does not make sense to you, stop and figure it out or wait until the guy who knows what he is doing can explain it. Good luck with your new engine.
Old Jul 5, 2011 | 03:29 PM
06chevy5.3's Avatar
The block was bored 20 over last year and yes he wanted the spec sheet and pistons to check with. I bought a new crank cause my converter balloned and wiped out the thrust so i rebalanced it. I ball honed it before i put it together this yr
You sound very pissy .... I did stop and figue it out that is why this post is here.. each piston assembley is balanced to the crank that is what i paid him to do.. I could be wrong but i never heard of a boring each cylinder different and specific to each piston in the box sounds a little over kill to me
Old Jul 5, 2011 | 04:44 PM
MattSapp95_T/A's Avatar
Yea a lot of times they will mic the piston and then bore to match since the pistons may very slightly..... I would give them a call and find out whats up...
Old Jul 5, 2011 | 06:09 PM
06chevy5.3's Avatar
I did and he conformed the writing on the box was not for me... my question was if they are all balanced "weighed" the same nothing to do with bore size at all... That was only brought up cause Z06boy had to come over here beating his chest like a wild silverback gorrila, insulting the my intelegance and machinist that has built prolly a couple hundred more engines than him... just guessing
If you had your pistons bore macthed than good for you... have a cookie and give yourself a pat on the back for going the extra mile
thank you for the people that awnsered my question and helped me out that what this forum is for correct???
If u guys wana argue the issue about bore sizing I'll make another post dedicated to it
