LY6 vs LS3
Old Jul 10, 2011 | 06:30 PM
ponjohn's Avatar
Default LY6 vs LS3
How much power is left on the table with 1.1 points lower compression in the LY6 vs the LS3?
Can the heads be milled safely to bring up the compression?
Old Jul 10, 2011 | 06:44 PM
Jimbo1367's Avatar
Dont forget the difference in bore too. LY6 is 4.00 and the LS3 is 4.065 IIRC
Old Jul 10, 2011 | 08:48 PM
TXoldskool's Avatar
not sure about the milling...but how much power do you need? My LY6 is sporting just LT headers, a Holley 750HP Street carb and GMPP d/p intake, dual springs w/titanium retainers, chromemoly p-rods, and Comp cam...making plenty of power.
Old Jul 11, 2011 | 10:19 AM
ponjohn's Avatar
Dyno?
Old Jul 11, 2011 | 07:57 PM
TXoldskool's Avatar
not yet....
Old Jul 11, 2011 | 08:48 PM
hicksport's Avatar
431 rwhp ly6 TSP vvt-2 cam and a tune all at 6000 rpm.
Old Jul 12, 2011 | 09:44 AM
ponjohn's Avatar
EFI?
Auto?
Tque?
I'd like to put a 3200 lb car in the 10's with a/c and auto.
Old Jul 29, 2011 | 10:55 PM
futureuser's Avatar
This is what we've been waiting for. That's 18 more than my ly6 with a non vvt swap. Details please?
Old Aug 1, 2011 | 03:35 PM
-TheBandit-'s Avatar
He wrote a little bit about it in this VVT cam thread, but hasn't given a lot of detail.
https://ls1tech.com/forums/generatio...-vvt-cams.html
Old Aug 2, 2011 | 06:35 PM
ponjohn's Avatar
Wonder how much tque it made?
Old Aug 8, 2011 | 02:09 PM
futureuser's Avatar
Assuming the same cam, intake and externals, my guess is that an LS3 makes at the most 30-40 hp more than an LY6.
My LY6 made 65 less at the wheels through a 4L80e than a 2010 LS3 Camaro with a 6 speed. We had the same valvetrain upgrades, and very similar bolt ons. I think my transmission soaked up at least 25 more hp and the rest of the difference was the better pistons in the LS3, lighter valves and 3mm bigger throttle body, the later 2 probably being negligible.
Old Aug 20, 2011 | 12:04 AM
futureuser's Avatar
I need to edit the above post. Actually, I made 53 less horsepower and 39 less lb/ft torque and that was also through and LY6 throttle body. Considering that I am running the 4L80e vs. the LS3/6 speed, the LY6 is a great value. I also have to credit the Vengeance Stage 2 cam.
Old Aug 25, 2011 | 12:54 AM
hicksport's Avatar
If you'll read my post: 2008 LY6, L99 intake and injectors, TSP VVT-2 cam kit, 2 inch primary longtubes, truck TB, put down 431 hp and 409tq. I was and still triing to do this as cheaply as possible...Never have i said that there is more peak power to be had with VVT just more power when you want it, under the curve. Also I did the MPG on my car the other day over a 250 mile trip and it got 26 on the HWY I'm still impressed with the set up!!
Old Aug 25, 2011 | 12:58 AM
Midnite Magic's Avatar
Bore and compression will make maybe 20 rwhp more
Old Aug 26, 2011 | 03:47 AM
tiresmokinV8's Avatar
I think Hicksport is also running a t56 if Im not mistaken.
Old Aug 28, 2011 | 03:54 PM
futureuser's Avatar
I haven't seen a vvt cam with a torque curve better than my setup. Maybe I just got lucky. I'm definately not getting 26 mpg, though.
