EPS Cam Numbers - disappointed
Old Aug 25, 2011 | 10:20 PM
bwyffels's Avatar
Default EPS Cam Numbers - disappointed
2007 CTS-V that had a baseline dyno of 387/384. Afterward with temp within 4 degrees the numbers were 482/420. I expected more than 100hp gain with the following(also the gains don't really come on til about 4500rpms). I would have expected the gains to start closer to 3000 and be more. Am I way off or are those low for an ls2 with T56?
230/238 .600 / .615 112 + 2 EPS Cam
trickflow 225 heads milled to 63.5cc for 11.3 CR
Fast 102 intake
NW 102 TB
4" pipe with stock ls2 maf (would it be worth ditching the maf and going SD or going with a 100mm maf?)
YT ultra lites 1.7
7.55 pushrods
No Weeds Diverters
Injectors
Fast fuel rails
The car already had 1 7/8" Kooks with Lingenfelter CAI and full corsa without cats and a mcleod rps with billet steel flywheel. I'm not really hung up on the number I just thought that heads, cam, FAST and other mods would have netted more that 100HP gain. I also thought the gains with the lower intake number would have come on earlier....
Should I try a different cam? Please help.
Old Aug 25, 2011 | 10:36 PM
indeed's Avatar
Can you post both graphs?
Old Aug 25, 2011 | 10:48 PM
bwyffels's Avatar
I am having trouble scanning the after run, but will post it as soon as i can. Here is the before run. I know it looks too strong, but I was more focuse on the gain....
Old Aug 25, 2011 | 10:50 PM
bwyffels's Avatar
before
File Type: pdf
Old Aug 26, 2011 | 08:48 AM
redtan's Avatar
Seems like the original baseline was a little inflated, those seem like high numbers for just intake headers and exhaust, especially with the higher numerically gears the ctsv has over say a GTO with the ls2.
I would take you 'gains' with a grain of salt...what you should focus on is the final number. 482 at the wheels with h/c/i stock cubed ls2 is very good. You technically could be pushing 500 with an SD tune and maybe an electric waterpump. Both those numbers are very impressive with a 364.
That is also a just a medium-ish cam...with a 24x/24x duration cam and more lift you could be over 500. That is usually stroker territory...
Old Aug 26, 2011 | 01:04 PM
stumprrp's Avatar
I agree, that much power with a 230 cam is pretty nice man. My friends old 346 with the similar heads and a bigger cam made 455 so your doing good.
Old Aug 26, 2011 | 01:08 PM
melsie68's Avatar
Any track times?
Old Aug 26, 2011 | 01:25 PM
Patrick G's Avatar
LS1 Tech Administrator
You should do some data logging and see what kind of drop in MAP you get at WOT. That LS2 MAF is a choke in your system, but I'm not sure how much it's costing you. I haven't found too many people disappointed with a 95rwhp gain after it was already on top of a healthy combo...especially in a streetable setup.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Aug 26, 2011 | 01:33 PM
bwyffels's Avatar
I think the tune needs some more work. The car seems to have the idle hanging a little and doing some idle searcing. I think i am going to ditch the maf and go SD for the final tune. The car is a blast to drive, I just wish it came on closer to 3000 rpm instead of 4500, but it just means I need to get used to driving it differently. I am actually considering a 100 shot and a ford 9" as my next mods. lol. there is never enough....
Thanks for all the comments.
Old Aug 26, 2011 | 01:51 PM
2QUIK4U's Avatar
Those are pretty strong numbers for that setup. I wouldnt be worried. That is just a medium sized cam. Should make a nice DD. Take it to the track and see how it does.
