PTV checking with VVT cam
Old Jan 11, 2012 | 01:24 AM
kballs's Avatar
Default PTV checking with VVT cam
I'm mocking up my stock short block L92 right now for the first time. I have two cams here to choose from. The first I bought a while ago when I first bought the engine:
222/236 .566/.578 114 LSA Comp Cams 156-403-13 OR
TSP VVT3 230?? .620 lift?? cam which I bought after they were released.
I would have just thrown it all together but my heads are PRC CNC heads that have been milled .035", so I don't want to built it without checking PTV first.
I'm thinking the VVT actuator should be checked at full advance (the way it is at rest ) as well as fully retarded. Has anyone done this somehow and how did you temporarily lock the VVT actuator to fully retarded to check it that way?
Typically, retarding cam timing decreases exhaust valve clearance, and increases intake clearance, and vice versa for advancing timing.
Old Jan 13, 2012 | 07:03 PM
Jimbo1367's Avatar
I'd call TSP and get specialized assistance.
Old Jan 16, 2012 | 05:21 AM
6.0 Motorhead's Avatar
I modified an old phaser by removing the spring , sensor plate and locking pin, which is inside the phaser. I then drilled and tapped holes through the sides for two set screws that will move it by pushing on one of the vanes. One set screw advances it and the other retards it.
Old Jan 18, 2012 | 03:54 PM
JPH's Avatar
JPH
I believe 20* is maximum you would want the actuator to put in, before running into major issues.
Old Jan 18, 2012 | 05:53 PM
SweetS10V8's Avatar
Ive done it 3-4 times....
1. Install any phaser limiter your using. (Comp limiters allow 20* total movement, get the right one, there are two phaser part numbers and two different phaser limiters)
2. Install something to lock the phaser advanced while your in there. I milled a piece of stock to fit precisely.
3. Check PTV with it advanced
4. Open it back up and retard it against the phaser limiter
5. Make a new piece to lock it in place retarted
6. Measure PTV with the phaser retarded
Old Jan 18, 2012 | 06:05 PM
-TheBandit-'s Avatar
I like it. Thanks for posting Steve.
Old Jan 22, 2012 | 11:49 AM
kballs's Avatar
Default ptv
Thanks, makes total sense. I'll be doing it today. It would be nice if I had a spare, but no big deal to do it with the original. Mine's the early actuator, so it's 62 deg stock I believe. Got the right comp limiter kit, and just have to make a solid lifter from one of the old ones so I can do ptv and check my pushrod length.
I want to run the VVT3 TSP i've got. I could probably run the Comp Cam as is without any issues. It's under 600 lift and Comp uses a lot less spring press.
Old Jan 22, 2012 | 02:03 PM
kballs's Avatar
Default ptv checking
I'm doing this right now. Took apart my phaser and took a few pics to make it clearer for everyone. I didn't have to take the spring apart, but all 5 bolts have to come out to free the movement of the phaser. I put the comp limiter in and sacrificed some drill bit ends to make the internal stops to check ptv. I ended up using 21/64 and M letter drills for mine. This is what S10 was talking about.
Now I can head to the shop and see what i'm looking at for clearances.
Old Jan 23, 2012 | 03:18 PM
Thanks for the photos - makes perfect sense to cut the end off an old drill bit if you have the right size. I see the shape is a little different going advanced and retard which I assume is the reason you're using two different drill bits.
Are you going to use clay on the pistons or some other method for measuring PV clearance?
Old Jan 23, 2012 | 04:37 PM
SweetS10V8's Avatar
Exactly what I was talking about! Thanks for posting pics for everyone. Ive had to explain this a few times and will reference back to the pics from now on!
Phaser # 12585994 uses Comp limiter kit #5456
Phaser # 12606358 uses Comp limiter kit #5460
Be very careful when reinstalling the phaser for the final time, take extra time to be absolutely sure the alignment pin is aligned with the hole on the back of the phaser. Hope you have a 5 ft breaker bar! IIRC its 48lb*ft plus 90 degrees!!!!
Does the Texas speed cam come with the long bolt, like Comps does?
Old Jan 23, 2012 | 04:40 PM
My TSP cam came with the long bolt. It is manufactured by Comp Cams. I assume this si the bolt that you're refering to needing 48ft-lb plus 90*? Is that that resisted by the timing chain and crankshaft/flywheel stop? I wonder if I'll end up turning my engine stand over.
Old Jan 23, 2012 | 04:44 PM
SweetS10V8's Avatar
Youll need something/someone to stop your engine from turning for sure!!! That bolt is just for pulling the cam forward while you feel for the alignment pin to engage properly. Then you have reinstall a new GM phaser bolt #12588151.
That bolt/valve takes some serious torque upon final installation.
Old Jan 25, 2012 | 12:06 AM
kballs's Avatar
Default VVT cam choice
Thanks for the feedback guys. This is my first LS, but i've built many engines from old big blocks, to M5 reblocks when I was working for BMW to 2500hp QSK Cummins engines at my current job.
Info on VVT stuff is far between and well protected it seems, so if I can help more VVT engines stay that way, i'll do what I can do help people want to keep it.
I haven't even looked at my VVT3 cam yet so I don't know if it's got the long bolt in it. I did buy a new cam bolt/valve since it's supposed to be a single use piece.
Old Jan 25, 2012 | 07:52 AM
I'm not trying to rain on your parade, but if you read the instructions that come with the comp limiter it tells you not to take out one of the screws. The one screw you leave in and only loosen, has an extended end that goes all the way through the phaser and fits in between the coils of the return spring. Once you remove it you will probably never be able to get it back in between the coils and your return spring will not function properly. I found this out the hard way.
Old Jan 25, 2012 | 10:07 AM
Thanks. My brain wasn't functioning so well when I wrote that before.
Old Mar 16, 2012 | 05:06 PM
What did you end up with for clearance?
Old Mar 18, 2012 | 06:44 PM
kballs's Avatar
I ended up using the smaller comp cam I had. PTV is well in the safe now with about .110". I'm selling the VVT3 cam now in classifieds if anyone is looking. If not i'll just keep it until I build a stroker short.
Old Jun 12, 2012 | 08:26 PM
85MikeTPI's Avatar
I'm working on the math to degree my VVT-2 cam and check PTV. The catch is that the phaser I sacrificed for testing is my original L92 one, and I have a new L99 phaser, cam, and limiter that the motor will run on. My notes (all deg values related to crank):
The L92 phaser has 62deg of freedom, from 17deg advance to 45deg retard
The L99 phaser has 52deg of freedom, from 7deg advance to 45deg retard
Both phasers have 44 timing chain teeth, for 8.18 deg per tooth.
According to a CompCams Technical Note:
The L99 cam (189- core) alignment pin is 13deg retarded in relation to the L92 (156- core) pin.
So I want to set up the unsprung L92 phaser to represent the L99 phaser
Old Jun 12, 2012 | 11:00 PM
1989GTA's Avatar
So if one wanted to degree in the camshaft I assume you would want the cam in the full advanced position? Thank you for posting the pictures. I will be doing this with my L92 motor is a couple of weeks.
Old Jun 13, 2012 | 06:03 AM
85MikeTPI's Avatar
Ideally you would lock the cam at 0deg for degreeing, but full advance is easiest. You have to adjust the values for the advanced value, and know what the base setting is for your phaser.
