Roller Rockers for Solid Roller 370 w/LS3 heads
Old Jan 12, 2012 | 07:28 AM
bww3588's Avatar
Default Roller Rockers for Solid Roller 370 w/LS3 heads
really tossing around the idea of going with a solid roller cam in my 370 this time around. I like the stability and ease of hydraulic, but its time to move up in the world. Looking for a set of adjustable rockers for LS3 heads that won't break the bank. Also, any insight on reasonably priced lifters wont hurt my feelings either. of course, I'm not expecting to get out of this without spending more than a hydraulic setup, but i cant justify spending 1k on rocker arms alone.
Thanks in advance.
Old Jan 12, 2012 | 07:33 PM
v8pwr's Avatar
The lowest priced ones I've seen that I would trust are the T&D rockers for $1200 which are the same as the Comp Cams. Jesel has a new SS series that's adjustable but they're $1400+. Which ones did you find for $1k? I haven't seen too many available for the LS3/L92 heads.
Old Jan 12, 2012 | 10:28 PM
odarabla's Avatar
How high are you planing on spinning this motor? With a good hydraulic setup you can spin your motor 7500+rpm. I have my rev limiter set at 7200 but with my setup I am sure I could spin it to 7400-7500 with no issues.
Old Jan 13, 2012 | 02:11 AM
Pwebbz28's Avatar
How high you want to spin? I'm spinning my solid roller ls3 to 8200. T&D are junk. Already had a set. Send me a PM if you want the info on the guy who built my rockers.
Old Jan 13, 2012 | 03:16 AM
bww3588's Avatar
Looking to set my rev limiter at 7500 and shift around 7200. As of now I have stock ls3 heads and a ported ls3 intake. No reason to spin it above their capabilities. However, I know a hydraulic setup will do what I want, but I plan in the future to add a better set of heads and intake.
Old Jan 13, 2012 | 09:16 AM
bluethunder364's Avatar
Why are T&D's junk??? Also looking for a set for my L92 heads
Old Jan 13, 2012 | 10:29 AM
87silverbullet's Avatar
I think at 7200 you have already reached the limit of a 370 cube motor with a stock intake and a bigger 408-427 a Fast intake will still suffice to feed it the air it needs so by keeping the CFM needs in check you can keep your rpms low enough to stay with a hydraulic valvetrain.
If you are going to go with a super Vic and a 4 hole 4150 then I can see the need of a solid roller setup because then you are going to need it.
Old Jan 13, 2012 | 10:53 AM
bww3588's Avatar
I think after looking at the prices for solid roller ****, esp for LS3 style heads, your right.
Old Jan 13, 2012 | 11:38 AM
Yeah, I don't think you will ever need a solid setup due to the factory style intake. It holds the engine back a little and you won't see those crazy rpms unless you go with a Vic intake
Old Jan 13, 2012 | 01:11 PM
bww3588's Avatar
As I posted earlier, I do plan to upgrade in the future. I was thinking along the lines of getting the valve train done in advance, that way in the future, it's as simple as an intake and cam swap, not heads, intake lifters and all that stuff.
A victor intake and a 4150 4 hole are not out of The question, just k question to be answered at a later time.
Old Jan 13, 2012 | 05:47 PM
JPH's Avatar
JPH
Thanks in advance.
Does a aluminum stud mounted rocker sit ok with you?
Old Jan 13, 2012 | 06:57 PM
Pwebbz28's Avatar
The T&D's I received had such horrible geometry that the pushrod moving 3/8 of an inch towards the intake thru ought the arc. Eric @ HKE has had this same problem but also said they have rectified it. They would not refund the $$ because they said it was a custom order. I'll take some pics of my valve train when I get home tonight and post up my rockers. It's not pretty or cheap though.
Old Jan 13, 2012 | 08:15 PM
S10xGN's Avatar
If you don't mind, check this post and advise if you can...
Old Jan 14, 2012 | 12:07 AM
bww3588's Avatar
as long as they are reliable, like last the life of the engine and dont break the bank. PM me with a link if they arent sponsor
Old Jan 14, 2012 | 01:02 AM
Pwebbz28's Avatar
Why 370 and not 408+?
Old Jan 14, 2012 | 01:04 AM
bww3588's Avatar
dont want a 408...right now.
next engine I build will be an LSX block based 4XX engine with a 350 DP kit.
Old Jan 14, 2012 | 09:51 AM
bww3588's Avatar
anyone have any experience with these?
http://www.compcams.com/catalog/COMP...g_2011_324.pdf
16765-KIT
looks like I can pick them up for right around 500 bucks.
Old Jan 14, 2012 | 10:57 AM
16765-KIT
That looks like a pretty good rocker for the price. I wonder how light it is compared to the stocker?
Old Jan 14, 2012 | 11:40 AM
bww3588's Avatar
not sure, none of the sponsors seem to sell them, and Jegs and Summit both have them, but its showing they wont ship out for a week or so. and according to comp's website, they are fairly new. Not sure if i like the fact they are 1.8's. On the plus side, I can run a smaller cam which in turn will be easier on the valvetrain south of the rockers, however on the negative, it puts more nose weight on the rocker itself. I also not sure about them being stud mounted, thinking that might raise some reliability issues...However, they are the first fully adjustable, full roller rocker assemblies for an LS3/L92 style heads that dont cost over 1k....
I think even if i do decide to stick with a hydraulic setup, I might still throw the money at these.
Would these still require periodic lash checks/adjustments with hydraulic lifters? I'm thinking no because this setup is near identical to SBC stock rockers that dont need any adjusting/checking once installed.
Old Jan 14, 2012 | 01:30 PM
Nah, if you stick with the hydraulic setup it will be maintenance free with those rockers but it will be an adjustable setup just like and old SBC.
Might be kind of a bitch adjusting them because you will be able to only touch so much of the pushrod with the guideplates and the head of the rocker in the way.
