Broken Tella Terra... Again
In my opinion, YT they have a tendency to fail after valve float and sharp rev limiters/fuel cut off events. That spikes the load on the rocker over the 425 max rating.
My springs were the Patriot Gold with open rate ~375 lbs and .631" / .644" cam lift. A higher spring rate may be contributing factor to early failures. Patriot Extremes springs have ~400 lbs open rate. It may not break immediately but shortly thereafter. Mine broke about 1 mile later after I hit the fuel cut-off. I partially contribute the rocker failure to having 26,000 miles on the springs. There are not many choices of springs for this cam, so I am installing new Patriot Gold and new YT rockers. The alternative for rockers are stock, but I don't like the geometry at high lift. For rollers, there are other rollers but I can't justify $1200-$1500 for Jesel or T&D shaft mounted rockers.
Note that the stock tune has a 6600 rpm fuel cut off. After the RPM drops 225 rpm, the fuel turned back on. If you don't let off the gas immediately, the rpm will bounce up and down 225 rpm quickly. I believe this can cause the valve spring to resonate and spike the open pressure well about the rated open rate.
So the solution may be: RAISE the fuel cut off to 6800 rpm, change the tune to 20 rpm drop fuel cut off, and make sure you keep well away from fuel cut off. I try to shift at no more than 6200 now.
How would you guys rank the Scorpions against the Comp golds? I hear Scorpions have come along way, but I have never really heard anything good or bad about the Comp ones.
And FWIW I TRIED to get a whole new set and told Doug my concerns with another letting go but he didn't really go for it. I only got the one. I even asked for a discount on a new set (which would have been okay)... but yeah he didn't really go for it. He seemed to think mine were produced outside of the time frame the bad batch was produced
even though I offered to email him my invoice for the motor build. And FWIW I TRIED to get a whole new set and told Doug my concerns with another letting go but he didn't really go for it. I only got the one. I even asked for a discount on a new set (which would have been okay)... but yeah he didn't really go for it. He seemed to think mine were produced outside of the time frame the bad batch was produced
