6.0 CHIRP dry fire
Hi everyone. I just finished building my second 6.0L. The first one lasted 6k then spun a rod bearing. This time its bored 30, forged bottom end, comp 273lr cam, ls6 intake. I busted it off yesterday and there is a chirping every 2nd revolution. There is not a belt on the car and the tranny is not yet in. The chirp sounds like it is coming from the drivers side. anyone know what this could be?
The first go around i plastic gauged the clearances. This time I had a shop put the bottom end together for me. Rods rubbing would be every revolution not every other right?? I marked the harmonic balancer with white chalk and it does chirp every other revolution. If its every other it has to be exhaust or intake i believe. The lifters are new. My pushrods are comp and are not bent. Rockers tight. I put the plugs in before i put the heads on so i dont see that being an issue but i will check. The motor turns over without binding. would a clogged vacuum line chrip like this? when i turn the motor with the throttle pinned in full flood it chirps too. and its consistent. i will check the plugs tomorrow any other ideas to throw in the pool??
Maybe push rod diameter too large, rubbing on passage in heads? Aftermarket rockers rubbing inside heads? Just thinking out loud...
the pushrods, heads, and plugs are the same ones i had on the last motor and there wasn't a squeak then. could that be the difference in lifters from oreillys for $13.00, and the ones from gm for $ 50.00 ?
alright guys found the problem. thanks for all the help it was my dumb mistake that made it chirp. i had the problem narrowed down to the drivers side so i pulled the plugs and turned over the motor. the chirp was gone. that narrowed me down to something compression related so i had someone turn the motor while i listened with a hose to try to isolate the problem. when i pulled my hose up to move it to another location i noticed there was gas on the end of it. long story short i had swapped my drivers side head with the passenger and a guide rod stayed in the head with one in the same side of the block so when i torqued the head down it smashed the guide rods off deep in the head and block. luckily the one in the block was exposed about a 1/4 of an inch and i was able to remove it. thanks for all the replys
