6.0L piston questions (LS3 heads W/ comp 54-469-11)
I called summit and they sold me a set of .30 over flat top pistons with no valve reliefs. Is anyone else running a 6.0L iron block with comps LSR cam 54-469-11 with the LS3 heads? I am worried about PTV. I want a set of pistons that are flat top with valve reliefs. Can anyone help me find a set of pistons that are 4.030 with valve reliefs? I dont want to risk the motor or mock it up with these pistons and find out they will not work and not be able to return them.
Diamond also makes great pistons. Wherever you end up going to get your pistons, make sure they have L92/LS3 valve reliefs. THey are a little bigger to accomodate the larger intake valve of the L92/LS3 heads.
Most aftermarket pistons require a 6.125" rod as well.
Hot Rod did an article a while back and I think the 227@ .050 LSr cam was the biggest they could fit without valve reliefs so yours most likely requires reilefs, but you ALWAYS have to measure for yourself.
EDIT: I found the article; http://www.hotrod.com/techarticles/e...t/viewall.html
I now am planning on running comps 54-456-11 cam and returning the 54-469-11.
specs on new cam are: 219/227 .607/.614 112
Last edited by SweetS10V8; 05-17-2012 at 06:08 AM. Reason: Fixed super long copy and paste
I found my old post where I said what my PTV was, I thought it was tighter than this. But that must have been about the 223 cam I tried before the 219.
SWEET! I got my cam and I have enough piston to valve clearance. I was a little scared I might not have enough because I had at least four things working against me.
1. Heads are milled .030"
2. Intake valve is huge, 2.160"
3. Piston is a true flat top with no valve relief
4. Piston sticks out of the hole .007-.008"
I ended up with .090" intake, .085" exhaust, I can live with that! I should start buttoning up the engine this weekend!
