New Cam recommendations?(current cam 262/266) 434ci stroker TFS245s..
#42
Just another thought if you want more braking power you may be able to shoehorn a hydroboost setup in there. I dont know what accessories/belt setup your using but you can find them on truck setups, the power steering makes brake pressure so your manifold vacuum doesnt matter any more. Worth a thought at least if braking is your only complaint of low idle vacuum
#43
If the only issue were lack of brakes this might be the easiest solution - http://www.summitracing.com/parts/CCA-5200/, but I think the bigger issue is making a more useable power band which he's addressing with a cam change.
#44
Did some of you guys miss my reply on the first page of this thread? The OP is getting drug by a C6 Z06 making 540rwhp and the Z is heavier to boot....I attached a link showing a 440 LS7 and what the powerband looks like with a camshaft VERY similar to the one in question..... While I agree this camshaft is obviously on the larger side of things, it is not "humongous" for 434 cubic inches....
That being said, we have agreed to exchange the camshaft for the OP to ensure he is completely satisfied with his camshaft selection. The new cam is on the way. I dont see it making anymore power and/or fixing his braking issue, but we will see soon enough.
See Link for complete details
https://ls1tech.com/forums/dynamomet...-complete.html
Dyno Graph
Dyno Graph
#45
If the OP is concerned about his brakes being bad due to the lack of vacume wouldn't a simple vacume tank solve his braking issue?
I run a vacume tank in my offroader just to make sure I have vacume for the brakes when i need it and it has worked very well, I have had no brake problems since its install however I did have some brake issues before it was installed.
#46
Thats some excellent customer service from Ron at Vengeance. Way to go big guy... Glad to know there are still shops out there who care about customer satisfaction as well as a tarnished name.
#47
I couldn't agree more, Ron went out of his way over a set of injectors for me when we found out the ones I order were back order. Went above and beyond, I think reputation is really important to the crew over there at Vengeance. VRD and Speed Inc have both blown me away at their willingness to help when things go awry.
#48
Thats great man.... I have never personally dealt with VRD But I almost purchased a 454 LSX With TFS 245's from them but ended up just going the ERL route bc of the weight savings over the lsx block. But Ron was very helpful when I talked to him. SPEED Inc. has never let me down either.
#49
Sawzall and Welder Mod
Who built the engine?
There's always the chance the camshaft was manufactured with an error in the specs.
My personal opinion is that the engine is overcammed, but as Ron posted above the current cam is not obscene by any means. It should still pull braking vacuum no doubt about it.
Unless this has already been checked out, something as simple as the ICL off by a few degrees will kill vacuum and power while not really affecting the idle. The compression numbers don't really support this argument however, 180ish across the board is about what I'd expect with that intake closing angle. I'd still spend an evening checking it out if it were mine before I removed it just to know for sure.
#50
Number in sig are SAE and smoothing 5.
#51
Unless the cam was ground wrong..or its too big (regardless of what your dynos show)..theres absolutely no reason my car should be idling 86-90kpa (basically 0 vacuum) especially since WOT is 98kpa...not to mention I have no brakes when coming to a stop.(14" f/r slotted with stainless lines) My brothers Vette has a cam in the 24x/25x range and his idle is 53-56kpa and when you remove a vacuum line it jumps up to 60-62. When I remove my brake booster hose from the intake the vacuum doesn't change at all...this means either something is leaking SEVERELY or the cam isn't working properly..I have tried 2 Fast 102mm intakes 1 stock intake...every vacuum source capped..with 0 change. I have done a compression and a leak down test both of which showed my engine is strong. Can you or someone else explain to me what else would cause almost no vacuum at idle or coasting..(when coasting its 78-80kpa). I have also swapped coils, plugs, wires, maf,even rechecked (2 times) my pushrod length to make sure the valves weren't stuck open. My friend has a 402 with a cam from you guys and it runs absolutely perfect.
On top of the vacuum issue is the power issue. This car literally feels like its driving through MUD under 4k rpms....and after that it picks up very nice but I shift almost as soon as I feel the power coming in. I have literally checked and rechecked every part of this engine....so im pretty much out of ideas. There is no reason why my setup weighing less with what im running shouldn't absolutely rock my brothers car. Unfortunately our dyno isn't here yet..but I can assure you my car is not making anywhere near 550whp let alone 600. If this new 247/252 can make near 550..and drive better mid range ill be more than happy. This setup running properly should get my car into the 9s.
P.S The customer service so far with Vengeance has been great. I plan on doing more business with them in the future. I appreciate swapping cams.
#52
What RPM are you shifting it at?
#56
****UPDATE****
Cam arrived today. I spent the evening installing and tuning it. It started up instantly and didn't stall...and this was on the old cams tune( the old cam would stall if you didn't give it a little gas) Idle KPA is now 66-69 as opposed to the 86+ that I was experiencing with the old cam.
I completely retuned the car (much easier with this time) and alls I can say is I am finally happy with my car. Not only does it feel like it picked up 100hp(too bad our dyno didn't come in time) but the car has brakes, NO LONG breaks up or bucks at the 2-3k range that no matter what I tried wouldn't go away, and finally feels like a monster. The power comes on instantly and at first I wasn't sure if the tires were spinning so easy because they were wet or what. This is a streetable cam. The old cam was literally dead under 4k.
After driving with this one Ive come to the conclusion that either A. The 262/266 cam should not be in a street car whatsoever, or B. The cam was ground wrong. The engine is ridiculously responsive and even sounds much better. The true test will be against my brothers car tomorrow. If everything goes well, ill finally be able to put some nitrous to this thing.
A+ to Ron@ Vengeance for your great customer service. I appreciate the cam swap and Im finally happy with my setup. =)
#57
Just throwing my thoughts out there as my car is the one in the dyno sheet Ron posted.
Dynos aside, that cam has been in my car for five years now. I didn't have anything to do with the tuning so I can't speak about how difficult or easy that was or what went into it.
I can say that I've driven the car almost across the country, and to work on nice days, and just out and about having fun. It dosen't stall at lights or buck and surge. My wife has driven the car without problem. At least one member on here has ridden in the car (ALGWS6) and was suprised at how good the drivability was.
The car pulls hard everywhere in every gear. And on the bottle it's just ridiculous.
If I had known the specs of the cam I wouldn't have wanted to use it. I told Ron how I wanted to use the car and what my power goal was and this is what they came up with. If I wasn't happy with the car, the cam (or something) would have been changed. I completely agree that the customer service from Vengeance Racing is excellent.
I'm glad the OP is happy with his car now, and I hope it makes the power he's after where he wants it.
#58
LOL I understand that
Glad you're happy and have such great customer service from Ron, more every sponsor should be the same way.
****UPDATE****
#59
If that is the case then the cam has to of been ground wrong because it was absolutely awful and I was about 5 minutes away from taking a deposit and parting my car out. This cam has brought new life into the car and has made it what I was hoping it would be in the first place.
#60
Pulled my nitrous kit out of my closet and blew the dust off of it today. Im finally comfortable giving this engine what its been waiting for. =)
The nitrous and purge solenoids are in the brake box(mirroring the fuel solenoid inside the box. I wanted to get both in there but they just wouldnt fit.
