my turn for a cam suggestion thread. EDIT: cam is in!
hey guys. ive spent countless hours trying to figure out what i want out of a cam, and theres just too many ls1 choices. heres my factors.
3800 stall. plan on keeping it because i love it.
i will be getting 3.73s.
the car is a daily driver, dont want a cam where im swapping spings every few thousand miles
Id like "decent" drivability, at least some lope as well.
I was thinking something like a 228, 230 camshaft. with my LT1 car it was so easy. not many choices, haha.
Id LOVE to make 400 rwhp. i dont know if its possible with the stall, but at 400 or as close as possible is my quest.
i currently have tsp 1 7/8 headers, will have tsp duals before i buy the cam, slp air lid, p&p tb and ls6 intake. will be picking up UD pulley as well.
if i cant hit 400 N/A with a decent cam and the 3800 stall, what will it take? fast intake/tb? 243 heads?
is there power to be had by switching to an lq9?
thanks guys, just looking for suggestions on a fun set up.
i put it in my friends 04 gto and it made 380rwhp on 1 3/4 pacsetters full exhaust and 243 heads and a conservative tune. used stock yellow beehive springs and stock pushrod length through a 6 speed
i can see you making 400rwhp with this no problem with alittle hand porting on the heads and that underdrive pulley, and yes this car was a DD
Found an idle video
Wow, those are some really tame lobes I really don't think it would be an issue either just a fyi. I would think a Comp Cam with Xtreme RPM or Xtreme RPM High Lift lobes with almost identical specs would make more power and still be easy on the valve springs. Better yet use LXL lobes and run a 230/230 or a 230/234.
Check out the the streetsweeper ht by new era performance(228/232). I just installed one in my car but have yet to get it tuned. It feels really good for not having a tune. Hopefully in the next few weeks Ill either have hp tuners or take it to a dyno.
cam only
http://www.neweraperformanceparts.co...mart&Itemid=54
cam kit
cam only
cam kit
I can spec you out a cam that will make 400rwhp through a locked 4l60e.
It will be slightly bigger than the cams you have mentioned, but not by much.
I like 98BluZ28's suggestion though to go with Extreme RPM and/or LXL lobes.
I would personally do a 230/236 .609"/.578" 112+2 camshaft for that goal or our Elite Series Stage 2 for LS1/LS2/LQ4/LQ9 which is a 234/240 .61x"/.58x 113+4 profile.
The 230/236 would most likely be a solid 390rwhp cam maybe 395 on a happy dynojet, but the 234/240 would get you real close if not there.
Added: both of those cams will have a nice sound to them with a definite lope at idle.
That would be awesome! would i have driveablilty issues with a 234/240 cam? is it gunna kill valve springs? I dont have good enought cam knowledge to spec one out myself.
If you have a 3800 stall and 3.73's and a good tuner I don't see drivability suffering tremendously. When you go to an aftermarket camshaft there will be some slight nuances, but that is just the name of the game when you're trying to shoot for a personal goal that is above average.
We can always back down the IVO event to gain some drivability back with a smaller intake duration by using a 230* intake lobe and taking some overlap out of the cam either from the exhaust duration or by widening the LSA.
All that said I still don't think you'll have any drivability issues with a good tune.
With the 3800 stall and the 234(lxl)/240(X rpm HL) 113+4, or with all LXL lobes a 234/238 113+4 it should work great, and I would think probably meet you goal. Another plus is that your valve springs should last a good while too with using those lobes!
IMO, contact Martian@Tick and get the ball rolling!
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
