Roller Rocker Suggestion for a 408 w/ big cam
hey guys,
I just spent 1k on my GTO to get it back together. I was using stock rockers on PRC 237 heads with a 251/259 .650/.650 112 LSA cam and it destroyed all 16 valve tips.
I am looking for a good roller rocker. I have found Harland Sharps with 1.72 ratio. how much will that .02 effect my lift? Those PRC springs are rated at .675 lift but I'm losing faith in them as I've already broken one so I'm not trying to throw more lift at them.
Not trying to have anymore problems and I believe roller rockers will do the trick. All suggestions welcome.
Derek
Derek
hey guys,
Derek
Derek
What's the rest of your valvetrain consist of? Did you set it up?
my setup was PRC 237 Heads, PRC .675" Lift springs, 7.500" pushrods, stock rocker arms, ls7 lifters with i believe .080" preload on them.
i measured my pushrods yesterday, again, and came up with 7.500" pushrods like last time.
i have read stock rockers are only good up to about .600" lift then the rocker starts pulling on the valve tip causing the valve to flex a bit and possibly torquing the spring and breaking it.
derek
derek
Its something else...many many threads about race engines with stock rockers. And there is threads too about aftermarket rockers beeing too heavy and they break or damage the valvetrain. There was some bad batches but still, the stockers are a goodnpiece except the needle bearings..which can be easily solve with the trunion upgrade.
Everyone that chymes in on every thread only has .625 +/- a thousandth or two lift. I am at .650" lift. I'm not saying anyone is full of ****, but what if it is just a tad too much for the stock rocker? I had 2 mushroomed valve tips, and the rest had a groove cut in the middle of them where the rocker stopped pushing it down. I have read the stock rocker is only good up to about .625" lift before it starts pulling on the tip of the valve.
ive measured my pushrod length a good 3 times with the result being 7.500" at about .080" preload. A 7.475" is too short according to my calculations.
A set of Yella Terra's have been ordered. Hopefully I dont have this problem again.
A couple of you said it was something else, can you elaborate on what that could be? It could only be the rockers or the pushrods as long as the valve tip isnt soft....
